How Do I Fix These Studs & Floor Plates??? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-02-2014, 07:02 PM   #1
How do I Fix these Studs & Floor Plates???
Hello All,
In need of some help to begin finishing my Man Cave!!!
After ripping out all of the wood panels I discovered that the basement apparently had water damage and the basement was not water proof. I have since had the basement professionally waterproofed. The problem i have now is that some of the studs had to be cut in half and some of floor plates removed. As a result I can't move forward w/ drywall yet.
I have attached a picture of the wall I'm trying to repair. FYI...that is concrete at the bottom. Any ideas on how I can replace the floor and wall studs would be GREAT!!! Then I can put my drywall up and be ready for the NFL season!!!!
Please help...a regular family guy on a limited budget in need!
FamilyGuy_01 is offline   Reply With Quote
Old 08-02-2014, 07:12 PM   #2
Rewards Points: 13,750
If that was mine I'd be removing all those cut off 2 X 4's and rebuild the whole wall with 2 X 4's out away from foundation and even with that raised area in the floor, or better yet in front of it, and use pressure treated bottom plate.
Then run all new wiring.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
FamilyGuy_01 (08-02-2014), r0ckstarr (08-05-2014)
Old 08-02-2014, 07:12 PM   #3
RE:How do I Fix these Studs & Floor Plates???
Here is a close up picture of the floor and the studs that were cut.
Old 08-02-2014, 07:19 PM   #4
Not sure they are 2x2 but I can check. I had a contractor come in and he said the existing frame was actually pretty good. I would have had him do it, but he was charging too much so I figured I good do it myself. Is replacement really necessary?
Do you know any resources to show me/ describe step by step how to lay the bottom plate and then bracket the studs?
Old 08-02-2014, 07:35 PM   #5
There's just no good way to patch this no matter how good that wood looks.
It would take you more time trying to patch it and the wall would be weaker.
Bottom plate gets Tap Coned to the concrete, then just mark it so the new studs sit at 16" on center. Studs just get toe nailed in place. #8 ACQ approved nails, 2, on one side and one in the middle on the other.
Check them with a level.
You want to hand pick every stud and plate. They need to be stud grade and as close as possible to being straight, no twist and minimum knots.
See that board in the inside corner, that what's called a nailer, It's for attaching the sheetrock to in the corners.
Old 08-02-2014, 07:57 PM   #6
Got it....hmmmm maybe I'll look into breaking down the wall and rebuilding it. Thanks for the shared wisdom.
Guess I'll grab my calculator and figure out how much to rebuild the frames. If you think of anything else, let me know.
Old 08-02-2014, 09:43 PM   #7
Rewards Points: 125
It might be easier to just splice in the missing stud pieces, then tie the wall together with 1/4" plywood for strength - rather than all new (one piece) wall studs.
But hey - framing is always fun - and a good learning experience if you've never done it before. Just google basic wall framing and I'm sure you'll find tons of photos/instructions.
bilug is offline   Reply With Quote
Old 08-02-2014, 10:11 PM   #8
Poor idea, 1/4 plywood has 0 strength.
It's going to require at least 6 times the number of cuts.
And that's not even including the number of cuts to get the hanging studs cut square.
Old 08-02-2014, 10:39 PM   #9
Rewards Points: 125
He's looking for a way to avoid tearing out the studs - it would work. Jump up to 7/16" plywood or something a little stiffer if needed.
Old 08-02-2014, 10:49 PM   #10
Fix it right or have a hack job your choice.
7/16 plywood, where would you even find that?
1, Install new pressure treated bottom plate, New studs one cut.
2, Patching it in, having to cut a bottom plate, one cut to get the cut off studs square, one cut the stud to make a cripple, another to sister a 4' patch, then have to cut up plywood to sheath the wall.
The mold spores would love that.
Old 08-02-2014, 11:15 PM   #11
Rewards Points: 125
Option 1 : Rip out the studs and put in new ones
In other words - this thread has no reason to exist.
I was giving another option since I assumed that isn't what the OP wanted to do. I'm not saying it is the best/easiest way.
Familyguy - Just rip out the existing and start from scratch. It really is the smartest option.
Old 08-03-2014, 08:04 AM   #12
joed's Avatar
Rewards Points: 12,924
This wall is not load bearing. It is only to finish the space.
I would simply put down a new plate. Cut pieces to fill the missing studs. Then cut a second piece longer than the piece and sister it along side. Drywall and be done.
If you didn't have all the electrical in there then I would consider replacing them.
The Following User Says Thank You to joed For This Useful Post:
CarpenterSFO (08-03-2014)
Old 08-03-2014, 03:06 PM   #13
Rewards Points: 1,910
Agree with joed. This wall holds nothing up except the drywall affixed to it. I wouldn't even bother to cut short filler studs. Just put down the new plate and a series of 18" to 24" studs adjacent to the existing studs. Sister them to the existing studs with 3" screws or nails.
Old 08-05-2014, 02:48 PM   #14
Rip it out and do it right the first time. You try to patch that then panel it or Sheetrock it and it'll turn out so wavy. Reframe properly. There are a ton of resources on how to frame walls in a basement. I would suggest a powder actuated nailer for the bottom plates
ChrisMDL is offline   Reply With Quote
Old 08-05-2014, 05:01 PM   #15
Rewards Points: 440
Man cave, not mansion. Go with joked's&w suggestion ( which is what mine was going to be but he beat me to it!!). Ron
ront02769 is offline   Reply With Quote
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 07:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 05:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
