Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-06-2011, 10:22 AM   #1
How do I finish open end of base molding
I have a balcony on both sides of a stairwell. There is nosing on both and they terminate at a common wall. I want to install standard three inch base molding on each side that will stop about an inch from each nose. I tried putting a return end on each, but with the square ends, it looks visually like both sides want to be connected. Even if it were just on one side, the squared end just doesn't look finished. It looks like something is missing. The best I could come up with was a large radius at the end which allows the eye to follow the curve down to the floor and not off into space. It's not bad, but I would prefer something better. Any suggestions would be appreciated.
fussyguy is offline   Reply With Quote
Old 12-06-2011, 10:29 AM   #2
A picture would sure be nice.
A return or a 45 deg. cut that does not go all the way to the back are the most common ways of doing it. They also sell end blocks in differant designs at Lowes or HD. There most often used when a DIY that does not know how to cut crown molding in the inside corners.
Old 12-06-2011, 10:30 AM   #3
Tileguy
Bud Cline's Avatar
Where the base terminates in the middle of nowhere, back-cut that end at a 45 degree angle with the long point on the face. Then cut another (small) 45 degree piece that will fit into the first 45, thereby returning the base-profile to the wall. This gives a finished look and makes everything pleasing to the eye. Has nothing to do with cutting crown molding.
Here ya go:
http://www.youtube.com/watch?v=eqYKKD1_hO8
The Following User Says Thank You to Bud Cline For This Useful Post:
Big Stud (12-06-2011)
Old 12-06-2011, 11:00 AM   #4
Crusty Old Dude
Big Stud's Avatar
Hmmmm , it says you tried to put a return end on each. Does that mean you did what Bud has suggested? That is what I have always done where base stops in the middle of nowhere. I have thought it looks great. Does your base have a profile on top? You said it had a "square end". In my area "standard base" will have an ogee edge on top.
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 12-06-2011, 11:04 AM   #5
Tileguy
Bud Cline's Avatar
That procedure will work with any profile - doesn't matter.
Old 12-06-2011, 07:07 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
any time you have a molding that has to terminate in an open section of a wall making it return is always the optimal method..
now what sepearates the men from the boys is the method of making the return...
woodworkbykirk is offline   Reply With Quote
Old 12-07-2011, 08:01 AM   #7
Crusty Old Dude
Big Stud's Avatar
I absolutely agree that a return is the best way to end a molding run that can continue no further. And it is really not that tough to do.
molding over molding, Can it be done? jerry1977 Remodeling 3 07-27-2011 02:31 PM
Base molding and flooring aunteemom Flooring 7 01-30-2011 09:03 PM
Base molding question aunteemom Carpentry 3 01-30-2011 02:08 PM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 02:49 PM
base molding and carpet doc70 Flooring 2 04-09-2008 12:33 PM
