How Do I Fill In The Hole For The Latch In A Doorjamb? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-29-2013, 03:14 PM   #1
How do I fill in the hole for the latch in a doorjamb?
The moron that installed the lock set butchered the jam. The door doesn't seal correctly with the dead bolt only the door handle. I need to move the opening back about a 1/4" and down about an 1/8". It looks like they used a jigsaw to cut out the opening. There's no jamb left where the screw for the strike plate needs to be. The screw at the top of the strike plate needs to be at the apex of the opening. I've attached a photo of the opening.
How can I fill this in and do it correctly?
near3 is offline   Reply With Quote
Old 11-29-2013, 03:35 PM   #2
Rewards Points: 13,732
What did they use a hack saw?
May be able to make it work with a Dermal tool and open up the latch plate.
Old 11-29-2013, 04:30 PM   #3
Rewards Points: 236
cut piece/s of a hard wood. and glue them in place. then use a small drill/chisel as needed
Fix'n it is offline   Reply With Quote
Old 11-29-2013, 07:37 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
make the morist uniformly square then make a full patch piece wood and glue it in with construction adhesive.. once the glue sets up fill any voids with autobody filler. sand everything flush then remortise for teh strike plate
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (12-17-2013)
Old 11-29-2013, 09:12 PM   #5
Thanks! I was trying to avoid going through all that but I guess I don't have any choice. One problem is that there isn't any thing directly behind where the patch will be will the construction adhesive hold it in place?
Old 11-30-2013, 05:54 AM   #6
Not perfect but an adjustable strike plate might work.
http://www.amazon.com/Prime-Line-Pro...e+strike+plate
Old 11-30-2013, 10:06 AM   #7
In a little over my head
Rewards Points: 706
There are also oversized striker plates, used for when a jamb has been damaged. Might be tall enough to require all new screw holes. They usually have the latch and deadbolt holes in one large plate.
ratherbefishing is offline   Reply With Quote
Old 11-30-2013, 12:47 PM   #8
ratherbefishing that would be great assuming the deadbolt and latch were close to being on the same plane. I think the photo covers the qualtiy of workmanship that was the standard and aligning the opening certainly isn't one of them but thanks any help is appreciated.
Old 11-30-2013, 12:57 PM   #9
Gymschu's Avatar
Rewards Points: 842
They could've used a sledgehammer and created a "better" hole than that.
Old 11-30-2013, 02:53 PM   #10
Rewards Points: 1,296
I would see if I could get one of these to work. http://www.homedepot.com/p/Prime-Lin...6#.UppPmVAo7IU
danpik is offline   Reply With Quote
Old 11-30-2013, 09:20 PM   #11
danpik thanks that looks perfect!
Old 12-01-2013, 06:37 PM   #12
retired union carpenter
Send a message via Yahoo to coupe
or you, can get a deadbolt keeper plate about 1'1/4 x3 have plenty of room for screws into good wood
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-04-2013, 02:45 PM   #13
Thanks everyone. The plate that danpik suggested worked perfectly. Had it in and the door is sealing in 10 minutes!!! Most of the time was rounding up the tools
Old 12-16-2013, 09:40 PM   #14
For future reference to anyone reading this thread, I had a customer that I installed new slabs in her whole house. She wanted the door handles raised, which I knew would be a pita, but I obliged.
Something had to be done about the strike plate and screw holes that were in the jamb below the new strike plate. I used Bondo for Wood as was very pleased with the results. Better then using traditional Bondo, has a wood color, is very hard and sandable with regular sandpaper.
maxwage is offline   Reply With Quote
Old 12-17-2013, 07:15 AM   #15
AHH, SPANS!!!
Rewards Points: 1,166
that is something I've not seen. seen plenty of red auto bondo and the grey all purpose available but not wood bondo. where do you find it?
hand drive is offline   Reply With Quote
small cover for 1/2" hole? wkearney99 Electrical 6 10-06-2013 06:06 AM
Hole in clapboard allowing birds to nest GarfE Pest Control 1 04-16-2012 11:14 AM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Fill hole in hard wood floor in discrete location? pcampbell Flooring 2 05-20-2008 08:23 AM
How much top soil to fill in this hole Malcolm Building & Construction 8 07-27-2007 06:29 AM
