How Do I Fill The Gaps With Natural Wood Crown Moulding? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 05:41 PM   #1
How do I fill the gaps with natural wood crown moulding?
I've always worked with painted moulding and caulk is clearly a wonderful thing. However, with natural wood, I'm finding it hard to hide the gap at the miter. I tried putty, but found it hard to get in the corners...very time consuming as well. Thought about mixing wood glue with saw dust, but I'm not sure how good of an idea that would be. I've included a pic, it's a very small gap, but I know it's there and will always see it. Any advise is greatly appreciated.
Cheers!!
Nate
neight is offline   Reply With Quote
Old 01-29-2011, 05:54 PM   #2
Carpenter
dtsman's Avatar
Stainable wood filler.
http://www.minwax.com/products/prepa...ood_filler.htm
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 01-29-2011, 06:47 PM   #3
Ha! I ask the stupid questions so other people don't have to. Got some in my tool bag and will give it a shot. I'm sure it'll be much easier than fighting with putty. Thanks!!
-nate-
Old 01-29-2011, 08:09 PM   #4
Contractor - Renovations
fungku's Avatar
The best way is to not have gaps.
If you coped the inside corners you wouldn't have that problem
I know that doesn't help you now that it's there, but even with stainable wood filler it will be noticeable.
fungku is offline   Reply With Quote
The Following User Says Thank You to fungku For This Useful Post:
Willie T (01-29-2011)
Old 01-29-2011, 08:15 PM   #5
DIY staff
Rewards Points: 7,174
Do your stain and first coat on finish before filling---the filler will block the bores of the wood and make a light spot.---Mike--
Old 01-29-2011, 09:11 PM   #6
Rewards Points: 5,336
Cheers!!
Nate
You work on a skill set where you transition from the caulk filling painted molding to the stained wood concept.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 01-29-2011, 09:15 PM   #7
Old School
Willie T's Avatar
We can't stress enough how important coping your inside corners is on natural finishes. And cutting your pieces just a hair long too, so the sprung tension will create an even cleaner intersection.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
BigJim (01-29-2011)
Tags
crown moulding , miter
How to fill gaps in hardwood floors ponch37300 Flooring 2 04-16-2009 05:30 PM
Best Wood Fill II Weeks Painting 1 02-04-2009 06:22 PM
Painting MDF crown moulding sk8z Painting 3 05-19-2008 05:11 PM
Gaps in drywall. What to use to fill them in. yummy mummy Building & Construction 13 01-02-2008 01:19 PM
wood moulding farrington135 Painting 2 08-25-2005 12:03 AM
