How Do I Attach Brackets To A Metal Door? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 02:48 PM   #1
How do I attach brackets to a metal door?
We have a metal (clad?) door with a nine-light window in it. My wife is wanting me to position brackets on it to support curtains. What is the best way for doing this?
This is a home center special, so I don't believe it to have a solid wood core.
Randell Tarin is offline   Reply With Quote
Old 06-16-2008, 03:38 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
A drill and sheet metal screws. Just make sure you have the right size bit for the job and drill the holes in the right place, cuz them holes in metal doors don't heal up.
Old 06-16-2008, 03:48 PM   #3
Is the metal thick enough to hold the screws? Aren't these clad doors essientially hollow-core doors with metal instead of luan?
Old 06-16-2008, 04:06 PM   #4
RDS
Rewards Points: 150
Use magnets!
We have the same thing -- metal door, bought at a home center, nine-light window -- and my wife found magnetic brackets for horizontal blinds. They work great! Very strong, and no drilling necessary. Someone probably makes magnetic curtain brackets, too.
Now as to *where* she found them, I couldn't say, but you might just try googling 'magnetic curtain rod brackets' or some such.
RDS is offline   Reply With Quote
Old 06-16-2008, 04:58 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
What I have done in the past is drilled small holes where the brackets are going to be placed and caulked the backs of the brackets , installed sheet metal screws and snugged them up , not to tight so they striped out cleaned off the excess caulking and hung the curtain. once the caulk has cured it acts as a secondary hold. Use a rubber based caulk not silicone.
Old 06-17-2008, 07:19 AM   #6
47_47's Avatar
Rewards Points: 62
How about double sided tape?
47_47 is offline   Reply With Quote
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
Mystery Metal Door Jams Risa Building & Construction 4 04-27-2007 11:19 AM
Under cut metal door jamb peter1 Flooring 7 03-19-2007 03:00 PM
