#1 |
How deep is standard bedroom closet?
Want to build a closet in my bedroom. How deep is a normal closet?
#2 |
the Musigician
average closet is 2ft. deep, wall to wall.
add another 6" to a foot for more room. width is however long you want to build it! DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Xtreme DIY'r
Yup, and I can prove it
![]() I went to new construction houses & took pics a while ago Measures 24.5" without sheetrock on both sides - so down to 23.5" after finish A little extra can't hurt
#4 |
the Musigician
The First Noel....
cute... DM
#5 |
Thanks guys. I have a 105 year old house so no closets in the bedrooms.
#6 |
If you have the space for an extra inch or two it will give your clothes more room to be what they want to be. Especially if you have coats or jackets.
#7 |
Drywall contractor
From a drywall standpoint, the 24-1/2 (I'd actually go 24-3/4") would be the most "efficient" and is kind of the "standard". Hang the back wall first. Rip an 8' sheet in half to stand up the sides (the 24-3/4" rough gives you a little room to play). Then run a header across the top of the front and stand up "legs" under it. (When hanging a whole house, there are usually "off fall" pieces to make the header and legs.) But you can make it whatever you want....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
| Display Modes | |
| Closet question: options and wiring diagram? | schnitz411 | Electrical | 6 | 10-24-2009 12:45 PM |
| Closet Size Help... | dcd22 | Remodeling | 3 | 09-27-2009 09:54 PM |
| Running laminate floor from bedroom into closet | bluefitness | Flooring | 4 | 05-09-2009 07:53 PM |
| Hardwood closet threshold question | DIY-Renovator | Flooring | 1 | 07-27-2008 05:42 AM |
| Closet Doors for non standard closet dimensions | jherschel | Carpentry | 7 | 02-22-2008 05:45 PM |
