How To Deal With Stripped Out Deck Screws - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 09:05 PM   #1
Rewards Points: 107
How to deal with stripped out deck screws
I was working on a deck dranage issue and had to remove some boards. I ran into a number of screws, with square heads that were stripped out. I ended up accomplishing what I needed to do, but I am wondering how you get screws out like that? Home Depot sold me an expensive screw extractor, but it did not work. My neighbor, who is a contractor, came over to help and he could not get the extractor to work.
Ranger1227 is offline   Reply With Quote
Old 06-24-2011, 09:20 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
They forced you to buy it? Take it back and tell them it didn't work if it didn't work.
There are screw extractors that have sort of a slightly twisted-square business-end on them. Find one of those type in the proper size. Then lightly tap it into what's left of the driving hole. Once you have a hook to work with chuck-it-up in a variable speed reversable drill and back the screw out slowly and carefully.
XXX
Old 06-25-2011, 03:23 AM   #3
Too Short? Cut it Again!
There are a variety of screw extraction tools out there but deck screws are particularly tricky. Things got mangled when the deck was assembled. Sometimes, I find it fastest to just get my multi-tool or reciprocating saw out, cut things off, and angle grind left overs flush and out of the way once the decking is free and clear.
The problem with a lot of box store extractor things is that the alloy they are made of is too soft and not a good match for the deck screws. See what a real fastener or tool supply store might have for your situation. Craftsman used to make a decent screw extractor system but it was not intended for multiple screws gone bad in a deck.
Old 06-25-2011, 07:48 AM   #4
Rewards Points: 125
Recently had a similar issue w/ stainless deck screws. They were a crappy alloy that stripped out easily, even allowing for differences between SS and hardened steel screws. I used a Dremel to cut slots in the heads, backed them out with a screwdriver enough to grab 'em w/ ViceGrips and backed them the rest of the way out. Sent a snarky email to the mfr and got the standard "Apparently YOU did something wrong" response, but they were just crap.
ThatDaveGuy is offline   Reply With Quote
Old 06-25-2011, 07:55 AM   #5
the Musigician
DangerMouse's Avatar
Slot 'em and flathead 'em, yup. That's what I end up doing.
DM
Old 06-25-2011, 05:11 PM   #6
Rewards Points: 107
Thanks for all of the replies. I was finally able to accomplish my task without taking off any more boars, But I like the idea of using the dremel to cut the slots. I will remember that for next time. I am taking the extractor back tomorrow.
Old 06-25-2011, 10:38 PM   #7
Rewards Points: 5,336
There is a learning curve with screw extractors. You need to drill the correct diameter hole for them to work.
Ron
B. Franklin 1759
Old 06-26-2011, 07:59 AM   #8
Rewards Points: 125
Screw extractors can be very handy lil items but they are finicky. You have to drill almost perfectly inline w/ the screw/bolt shaft so you are turning it, even slightly off-center or out of line and you tend to just rip the head right off. I've found they are the best thing for when a head is gone and you need to remove the remaining threaded shaft (easier to line up,etc.) but when there is still a head left on it, something lo-tech, mechanical bruteforce-ish usually works better.
Deck Restoration sdm6942 Building & Construction 1 12-10-2010 07:47 AM
Can I use deck screws with Hardibacker? spaceman spif Kitchen & Bath Remodeling 10 10-26-2010 02:11 PM
built a new cedar deck used galvanized instead of screws should i replace all nails? abbyaudi Carpentry 8 04-19-2010 10:57 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
