How To Create The "illusion" Of Straight With Door Casings? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-03-2012, 07:34 AM   #1
Question
How to create the "illusion" of straight with door casings?
I am working in a furniture store where two french doors (9'high by 4' wide) have been installed for a display on a very uneven and sloping floor (from east to west the floor loses 3.5" over 12.5' and dips 3/4" in the middle). One of the frames is approx 1/2" from vertical and the other is about 1 1/4" from vertical. I've been asked to put casings on the doors but I'm wondering what my best option is for getting the doors and casings to at least give the appearance of being straight? Thanks for any suggestions.
WayneGee is offline   Reply With Quote
Old 04-03-2012, 07:46 AM   #2
kwikfishron's Avatar
Rewards Points: 428
Since itís just a display build a level sill on the uneven floor and install the doors on that then you should be fine.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
WayneGee (04-05-2012)
Old 04-03-2012, 08:00 AM   #3
Rewards Points: 2,212
The sill may be a tripping hazzard.
Would the actually build a floor for this display?
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Old 04-03-2012, 08:08 AM   #4
Rewards Points: 428
I was assuming no one would be passing through a display.
Old 04-03-2012, 08:49 AM   #5
thanks for the replies. The doors are actually already in place (one of them is walk-through) so my only issue is the casings and how to get everything to look straight. Should I follow the line of the straighter of the two doors and case everything vertically from there? Or is it better to stick with the lines of each door? The casings will be white but the doors are dark mahogany which I think will amplify anything which is out of line?
Old 04-03-2012, 11:32 AM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
with sitations like that you almost have to mock it up to see how it will look. finish work isnt always about making everything perfectly level and square. it sometimes requires tricking the eye to think things are correct.. this requires keeping lines parallel. if you start messing around too much it can become a real mess really quick or if done correctly it will look like it was always there
woodworkbykirk is online now   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
kj6887 (04-05-2012), WayneGee (04-05-2012)
Old 04-03-2012, 11:17 PM   #7
I don't understand this. Is it just the floor that's out, or is it the jambs too? If it's the jambs, then shim them square and cut the doors if necessary.
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
Old 04-03-2012, 11:36 PM   #8
Sounds like doors are hung, but proably best to rehang, and cut parallel to floor and case.
Old 04-03-2012, 11:47 PM   #9
Better see how far off the floor is or leave a big gap underneath or one of the doors won't open!
Old 04-04-2012, 10:28 PM   #10
Could be, depends on if it slopes away from the hinge side or towards it
Old 04-05-2012, 10:07 AM   #11
Thanks to everyone for the responses. I managed to get the job done and looking pretty good without too much re-working of the framing. I'll post a picture when I've finished which may explain the issue ,ore clearly. Cheers!
The Following User Says Thank You to WayneGee For This Useful Post:
mae-ling (04-05-2012)
Tags
casings , doors , frames , uneven floor , vertical
Perfectly straight line Casey Flooring 13 04-05-2011 10:18 PM
Storm Door Not Hanging Straight Jay 78 Windows and Doors 14 03-08-2011 03:36 PM
Getting the first line of laminate straight stevenson66 Flooring 5 11-12-2010 12:00 PM
Make them grow straight cprao Landscaping & Lawn Care 9 07-05-2010 03:20 PM
Repacing HP condenser with straight cool. bama7x57 HVAC 0 07-26-2009 01:32 PM
