How To Create Hinge Mortise On Bevelled Hinge Edge Using A Router & Jig? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 01:22 PM   #16
Rewards Points: 2,212
with only 1/32 gap the leg will flex enough to clamp.
If your in the business buy a good jig, for a one-of thing this works excellent.
mae-ling is offline   Reply With Quote
Old 07-28-2012, 02:10 PM   #17
Rewards Points: 37
You're right. I never thought about it flexing.
I would buy a jig foor what I want to do if one existed but they don't. All commercially available jigs only work for square cut edges not beveled edges, hence the reason for my starting this thread. If I bought one of these jigs and cut the bevel using it then the front surface of the hinge at the pin would be flush with the bevel whereas the back would be recessed. Not a good look. Squaring off the beveled edges is not an option since this would remove the veneer and expose a different wood underneath resulting in the edge not matching the face of the door, not to mention the small risk of not cutting the door square.
Toronto is offline   Reply With Quote
Old 07-28-2012, 09:06 PM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 392
Originally Posted by Keith Mathewson View Post
That is just too neat Keith, I have both links bookmarked, I just couldn't figure out how a hinge could be mortised with a plane, now I see how. Thanks a lot.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-29-2012, 10:07 AM   #19
DIY staff
Rewards Points: 7,174
Thanks--I loved the hinge plane---never saw one of those before---very informative video---Mike---
Old 07-29-2012, 10:51 AM   #20
Could have used one when I was doing insurance work replacing doors after break-ins, I too had not heard of it.
Old 07-29-2012, 10:53 AM   #21
Rewards Points: 190
I made a mahogany front door and like you I did not want to put nail holes in the edge of the door to hold the jig. I played with U shaped jigs and ways to clamp them and finally decided to just nail the jig to the door edge. I felt it was safer than to try to attach the U shape jig and have it slip and take a bite out of the door. Two tiny dots on the door edge on either side of the hinge can't be seen when filled and stained.
How to create hinge mortise on bevelled hinge edge using a router & jig?-img_0645-small-.jpg   How to create hinge mortise on bevelled hinge edge using a router & jig?-img_0646-small-.jpg
zircon is offline   Reply With Quote
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
Create my own bull nose edge on tile? bmacdona General DIY Discussions 25 04-15-2011 10:44 PM
Router Advice diyheroe Carpentry 0 09-24-2010 09:09 AM
What router bit is used to create the inside angle on a window stool? Mikedks Building & Construction 7 05-12-2008 04:43 PM
