#1 |
How to create hinge mortise on bevelled hinge edge using a router & jig?
I have 10 sapele mahogany veneered solid core doors 1-3/4 inch thick. They came pre-bevelled on both the hinge and strike side. I have to create the hinge mortise on the bevelled hinge edge for the 4-1/4 inch hinges I have. Does anyone know what the easiest way to do this would be using a jig and router?
I was going to make my own jig out of wood and then use the router to make the mortise but now this seems a bit more problematic because if the jig was at a 90 degree angle to the door face the mortice would then be cut at this same 90 degree angle and would therefore be deeper towards the back of the bevel than at the front. I want the mortice to be the same depth towards the back of the bevel so the face of the hinge is flush with the bevelled edge of the door, not a bit deeper towards the back of the door edge. Any ideas? How would I make a jig to do this or is there one I can buy (but I don`t think I would find something to buy readily available as I am in Toronto and most pre-made jigs seem to be only available online in the US)? I don`t want to chisel these out by hand as I don`t think I would be very good at it and these were very expensive doors to replace if I made a mistake. |
#2 |
Super Moderator
Sears has ,or used to have, a metal hinge template that is nailed on the edge of the door---therefore making the beveled edge not concern---see if they still have them---
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
Super Moderator
How to create hinge mortise on bevelled hinge edge using a router & jig?Like this--Google images--sears router hinge template
#4 |
Thanks but I really do not want to put 6 nail holes (2 x 3 hinges) into the edge of these expensive sapele mahogany veneered doors. I see there is a Hinge Mate HM-1100W door hinge template in aluminum that has received some good reviews and can be adjusted using an aluminum angle on the edge so that the template follows the bevel. The problem is I am in Canada and they don`t have them here and I need to start hanging these doors tomorrow.
I was hoping someone might have an idea on how to create a jig out of wood that I then could use with a router to create this mortise. A jig, that is, that would sit flush against the bevel. |
#5 |
Mkae your own jig that clamps onto the door, kinda a U shape to wrap the door
#6 |
Haverhill Trade 1965
They sound like a reversible door, left or right. The hinges should be put in with the hinge pin on the side of the longest or widest edge. The depth should be uniform as the hinge will not be affected as it is rotating in that direction. It will simply rest in a slightly open position. They used to make but hinge cutter, (like a rectangular leather stamp) for most hinges, size & depth. You mark the spot, place the sharpened edge on the door and tap it in with a hammer, remove it and chisel out with a good 1/2" to 3/4" sharp chisel.
#7 |
It seems to me that that is what I have to do. I`d have to measure the angle of the bevel and have the bottom a part of the U at that same angle. I would have one leg of the U and the bottom of the U glued and screwed together, ie an `L`shape, but what I am not sure about is how to make it so I can clamp the other leg onto the L. I want it to be a tight fit but that would mean possibly marring the veneer finish when I slide it on so I would want it to be somehow loosely connected to the L so that I could then tighten it on to the edge of the wood door with all 3 faces of the U tight against the it.
Does anyone know how I could design this custom wood piece? What kind of mechanism could I use to fasten the other leg of the U loosely to it so then I could tighten it? If anyone has a sketch that would be great. |
#8 | |
How to create hinge mortise on bevelled hinge edge using a router & jig?Quote:
#9 |
[IMG]
[/IMG]Make jig inside legs just 1/32 or so wider then door width, after felting the inside edges so as to not scratch the door. The top big enough for your router, The hole the size need for a pattern bit or collar to ride inside of. The top edge of the legs are cut to the angle of you door edge. Use a clamp to camp the legs to the sides of the door. Last edited by mae-ling; 07-27-2012 at 09:30 PM. |
#10 |
Thanks for that and for going to the trouble of posting the picture. But, I think that even with felt that assembly might run the risk of moving slightly when the jig is used.
I think I found the answer in the video below. This guy made an adjustable jig to mortise different sized hinges in doors of different thicknesses, albeit his is for doors where there is no bevel on the hinge side, ie his jig profile is a U with all sides perpendicular. I would have the bottom of the U at a slight angle to reflect the angle of the bevel on my door edges, like you did in the above picture. I don`t have to make mine adjustable for hinge size as all my hinges are the same size. What I do want is to be able to adjust is the back fence. ie the one leg of the U which you can see in the video that he is able to slide back and forward in order to clamp it on tightly to the door with removable clamps. This is much better than making it the exact thickness of the door or slightly larger and using felt I think. Clamps would make it very secure without any chance of moving when the router is used. I would also make 3 different spacers in the shape of an L to place against the top and bottom edges of the door (with the long side running along the door face) which I would then slide the jig against so that the spacing of the 3 hinges would be exactly the same on each door Last edited by Toronto; 07-27-2012 at 09:47 PM. |
#11 |
Stair builder
How to create hinge mortise on bevelled hinge edge using a router & jig? |
| The Following User Says Thank You to Keith Mathewson For This Useful Post: | mae-ling (07-28-2012) |
#12 | |
STAFF
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#13 |
My two posts were supposed to go together, would use clamps as well, felt is there to protect the door.
Very similar to the other design but not adjustable. |
#14 |
Stair builder
| The Following 4 Users Say Thank You to Keith Mathewson For This Useful Post: |
#15 |
Yes but how do you clamp tightly and stop the jig from moving as your use the router if at least one of those legs drawing don't move? And if it does move then how is it attached to the to part that has the cut out for the jig? I guess one could clamp the two legs, then screw the loose leg in from the top but that's a lot of work to do every time you do another hinge.
| Display Modes | |
| Mahogany Door Jamb - What nails and where? | Toronto | Carpentry | 25 | 07-26-2012 08:08 PM |
| Create my own bull nose edge on tile? | bmacdona | General Discussion | 25 | 04-15-2011 11:44 PM |
| Router Advice | diyheroe | Carpentry | 0 | 09-24-2010 10:09 AM |
| What router bit is used to create the inside angle on a window stool? | Mikedks | Building & Construction | 7 | 05-12-2008 05:43 PM |
