Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-13-2006, 11:53 PM   #1
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
How to clean up the edges after a jig saw???
Hello everyone,
I decided to make a couple corner speaker shelves to hang up on the wall. I had to cut the front of the shelf with a jig saw to make it rounded. Now after my cuts it still doesn't look right, so i figure i have to sand it straight to the line, i made my cuts on the outside of the line, figuring i had to sand it straight. What do you guys use to sand with? All i have is a Black & Decker finishing sander.
Thanks,
Sellncars
Sellncars is offline   Reply With Quote
Old 09-14-2006, 06:44 AM   #2
Master Craftsman
Big Dave's Avatar
A belt sander works best. The finish sander will work but you will need to start with a fairly course grit and work your way back down to a finer grit.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 09-14-2006, 02:08 PM   #3
They're all fixer-uppers
J187's Avatar
Sellin - I have the Ryobi Belt/cicular sander for this purpose. Its like $99 in hardware stores and comes in handy all the time. It's great for molding and small little handy projects like buiding small shelves and such.
J187 is offline   Reply With Quote
Old 10-01-2006, 05:40 PM   #4
Extreme DIY'r Adk's, NY
if you have a router table and variable speed router you can buy a mini drum sander bit, then you can work like a pro!
crecore is offline   Reply With Quote
clean chimney jckkcj General Discussion 13 08-25-2012 06:56 PM
Brick face house clean up - improvement jovo14 Building & Construction 1 08-09-2007 04:40 PM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-15-2007 12:12 AM
how to clean double pain windows DIYER33 General Discussion 3 04-12-2005 12:53 PM
