How Can This Be Safe? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 10:07 AM   #1
the Musigician
DangerMouse's Avatar
How can this be safe?
I saw this chair, but I'm wondering how the shown joints could possibly be strong enough to hold the weight without breaking backwards. Mortise and tenon is the only joint I can imagine they used, and no way would I trust that joint to hold kids, let alone adults as they advertise it can!
http://www.stokke.com/en-us/highchair.aspx
It just seems unsafe to me.
Any comments?
DM
Old 02-02-2011, 10:25 AM   #2
Framing Contractor
Any comments?
DM
Maybe they're mortised and glued in?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-02-2011, 11:04 AM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
It's safe, by China's standards. Probably be recalled at some point. :P
Definitely does not look very safe. The pressure that is on that joint is probably 10x the weight that is actually on it, because of the leverage. Keep in mind the added stress if the baby is not sitting still.
Old 02-02-2011, 11:45 AM   #4
Buying the first round
LIHR's Avatar
It's been around since 1972 so I'm sure it's a proven design. The chair requires assembly, and the joint in question is assembled at the factory and not something they leave for the end user to attach.
I'd put my money on some type of internal metal fastener
LIHR is offline   Reply With Quote
Old 02-02-2011, 12:51 PM   #5
Rewards Points: 506
Any comments?
DM
Why don't you buy one, check it out, and if its bad enough in your opinion you can give it a Mike-Holmes-Style tongue lashing on this forum!
jlmran is offline   Reply With Quote
Old 02-02-2011, 12:51 PM   #6
Rewards Points: 272
Cannot remember where this was being sold ( old age setting in ), but this item has since been removed from store shelves.
fixrite is offline   Reply With Quote
Old 02-02-2011, 01:42 PM   #7
Old School
Willie T's Avatar
I see no problem with it. I have researched the safety aspect of it online, and all I can find is a possible tipping problem from incorrect assembly by the end user. No problems with the joint were found in my searching.
As far as I can tell, it is still being sold for $250, a hefty price.
Here is an alternative that gives a more solid "look", and only costs $90, I think.
http://www.onestepahead.com/catalog/...mSource=Search
Willie T
Old 02-02-2011, 03:30 PM   #8
Kind of hard to tell how strong the joint is, without seeing it. It's possible that it's plenty strong - depending on the materials from which it's made and the construction method.
I'd be more concerned about the chair tipping over if the child moves around - looks top heavy to me.
Gdgarth is offline   Reply With Quote
Old 02-02-2011, 03:34 PM   #9
the Musigician
If I had one, I'd add two extra supports.
DM
Old 02-02-2011, 03:35 PM   #10
Framing Contractor
If that's true and that same chair has been around for 39 years, it has to be safe.
Joe Carola
Old 02-08-2011, 09:31 PM   #11
I grew up with baby chairs like that, 20 some years ago in Norway.. I remember my cousin at about 130lbs sitting on a chair like that..bouncing up and down.. it doesn't look very solid, but it held his 130lbs..with higher effective loads from the bouncing action.. just my 0.02.
jarleifvaagen is offline   Reply With Quote
Dryer vent butterfly damper safe? TryHard Appliances 9 01-17-2011 03:44 AM
Freestanding/portable safe home heaters?? sugarmama HVAC 5 10-30-2007 09:23 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
