How Can I Strip This? (coffee Table, Side Molding) - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-21-2010, 11:36 PM   #1
How can I strip this? (coffee table, side molding)
I have this coffee table I bought off craigslist. I have been sanding it down, and all I have left are the sides. I've been working on one side of this for about... 3 hours ( see photo) .. There must be a better way, as I can't get into the corners with either a sponge sander, dremel, paper and of course not a power sander. I also noticed that... the lower part is a little real wood, then a few milimeters under is Particle board! So I have to be very careful..
This is really the max I can do with the tools I have.
L4nce0 is offline   Reply With Quote
Old 07-22-2010, 08:06 AM   #2
Rewards Points: 780
Can you take it apart to sand each piece individually?
gma2rjc is offline   Reply With Quote
Old 07-22-2010, 08:38 AM   #3
I did that with the one you see, but it turns out it has covered nails and technically broke it. I can do it to all sides, and cost some struct integrity.
Old 07-22-2010, 09:05 AM   #4
Rewards Points: 780
Sorry about that. I didn't mean that you should take it apart, I just wondered if you could.
Old 07-22-2010, 09:09 AM   #5
nono I did it last night. =)
Old 07-22-2010, 09:45 AM   #6
Rewards Points: 780
I have a huge sanding project I've been putting off for a long time. Mostly because it involves getting into the corners and working around spindles.
It's my stairway and it used to have carpet. When I pulled it off, I found out there has never been a finish put on the treads and everything needs to be sanded.
Good luck with your table. Hopefully someone here will be able to give you the advice you need.
If you get time, post a picture of it when it's all done.
Old 07-22-2010, 11:29 AM   #7
Yeah defiantly. I just know I can't spent 3+ hours and only get 80% sanded.. for one side for 3 items.. My dad made mention of chemicels I could use, or I could keep it as a "rustic" look... I rather not. (new one is lighter color)
Old 07-26-2010, 10:47 AM   #8
I'm fairly disappointed that I didn't get a real solution here... I went to home depo, they sold me a lacquer that took it right off. Though it is darker then I wanted, I have no other solution. I put the new varnish on last night, 2 coats, 3 hours apart and did some basic sanding. I'm trying hand not to get any dirt on it, but that may not happen it my garage. I'll post photos soon. Also I'm putting less varnish on the parts I had to use chemical strippers, as it's already fairly dark, and it's a fairly light stain.
Super glaze bar table finish jlwiu1 General DIY Discussions 18 02-05-2016 03:52 PM
cutting crown molding for cope cuts billyg Carpentry 6 05-04-2009 06:18 PM
Want to build something with sea shells - coffee table? Tommy2 General DIY Discussions 13 12-09-2008 10:10 AM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 07:44 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
