How Can I Prevent Wood Discoloration From Sprinklers? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2008, 02:56 PM   #1
Ummmm...
Shpigford's Avatar
How can I prevent wood discoloration from sprinklers?
In just the 6 weeks or so that we've had our sprinkler system running I can already see some obvious discoloration on our fence from where the sprinklers have hit it.
So two questions.
1) How can we prevent it from getting worse?
2) Is there any way to fix what's already discolored?
Shpigford is offline   Reply With Quote
Old 06-21-2008, 10:40 PM   #2
Registered User
Termite's Avatar
The discoloration probably can't be completely eliminated, although it can probably be minimized. If you haven't installed a HIGH QUALITY stain/sealer on the fence, that is a must. You may need to power wash to get some of the staining to look better. As long as water is hitting part of the fence, that part is going to look somewhat different than the part that isn't subjected to such intense "weathering".
The best way to deal with this is not to water the fence! Can you install some different heads on your irrigation system, or aim them so they don't hit the fence???
Old 06-21-2008, 10:43 PM   #3
Ummmm...
Shpigford's Avatar
I'll take a look at some sealers to see if that helps some. The sprinklers aren't really directly hitting the fence, they just spray long ways down the fence and so a good bit of mist from the sprinklers hits it.
Old 06-21-2008, 10:51 PM   #4
Registered User
Termite's Avatar
I'd avoid the cheapo (thompson type) sealers. You're going to have to spend $30/gallon to get quality stain/sealer.
My choice is Penofin. The stuff is awesome.
Old 06-22-2008, 06:34 AM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
I agree with the kctermite. but may I add one thought ? is the discoloration due from iron riched water from your well. if this is the case there isn't anything out there that will prevent this from happening. you will have rust forming on the surface of your sealer also. just something that is a big problem here in my locale. if not! kctermite has the cure. good luck BOB
Old 06-22-2008, 08:51 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As buletbob stated: The minerals in your water "may" repeat the staining process again....
- Build Well -
Tags
discoloration , sprinklers , water , wood
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 12:24 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
