How Can I Finish Framing This Window? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 11:48 PM   #1
Rewards Points: 105
How can i finish framing this window?
I have a small 18" x 33" basement window at grade or maybe a foot above. The sill is ugly and the metal frame is all rusted up.
I want to replace it with glass block, which I know how to use. My problem is the wall had an obstacle which forced me to frame about three inches from the wall.
On the other glass block window I did, I framed 1-by around the opening, and then screwed the plastic liner bottom for the glass block into both the wooden framing and the metal on the jamb. The jamb is about 2 1/2 inch thick, so with the 1-by it worked out well, almost flush.
But here, the gap makes it tougher. I was planning on sanding down the rusted metal frame, and then attaching a 1/4 or 1/2 inch wooden pressure treated sheet (cut to fit and possibly shimmed on the internal stud sides) to create a "box" on which I can put the glass block and morter.
Is this the best option I have at this point?
jdm001 is offline   Reply With Quote
Old 01-18-2011, 10:22 AM   #2
Rewards Points: 5,336
You just bridge the gap with a wider piece of wood. In this case, maybe a 2x6. I'd put the glass block in first and then center the frame around the block. Decide how you want the frame to sit, depth wise, and get a size you can use. You can rip it down to the width you need.
Ron
Old 01-18-2011, 07:01 PM   #3
Rewards Points: 105
Ron
You mean over the stud an frame and nailed/screwed down into the wood frame and onto the sill, right?
Or do you mean pressure fit it to the exact width so it's snug, then secure it side-to-side through the width of the stud?
Old 01-18-2011, 09:21 PM   #4
This one.
Ron
window framing question wengang1 Carpentry 2 10-16-2010 09:05 PM
framing new basement walls around exisiting window mcbagel Building & Construction 2 10-16-2010 07:06 PM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 10:33 AM
Need Help Framing a Window johnpma Carpentry 10 06-11-2009 11:42 AM
clipped FINISH vs. FRAMING nail amakarevic Building & Construction 4 04-25-2008 04:46 PM
