-   -   How can I create this piece? (http://www.diychatroom.com/f14/how-can-i-create-piece-170028/)
Bradeno 01-24-2013 06:01 PM
http://www.homedepot.com/webapp/wcs/...N#.UQHImR3C1pp
I am trying to create a 5"X8' casing piece with a cross-section similar (doesn't have to be precisely identical, just want rounded flutes) to the one in this picture, but can't find the proper router bit.
How would this piece be done? Would I need a custom fab'd router bit or could someone post a link or two to let me know what tool I need to create this?
Thanks!
woodworkbykirk 01-24-2013 06:54 PM
link doesnt work
Bradeno 01-24-2013 07:30 PM
http://www.homedepot.com/webapp/wcs/...N#.UQHf-R3C1po
Hmmm, I dunno why. I just grabbed the link a few hours ago.
There it is again.
Hopefully it will work this time.
woodworkbykirk 01-24-2013 08:19 PM
thats not a flute profile thats more of a multi bead profile. to create that you need a molding knife and a shaper table
funfool 01-24-2013 08:30 PM
Tell us more about the project, why 5" tall trim and will you paint it or stain, where will it be going?
ktkelly 01-24-2013 08:39 PM
http://www.woodcraft.com/PRODUCT/200...FQSqnQodGFoAUQ
This bit, multiple passes, after you set up a jig/guide, or router table.
Simple but still a PIA.
cleveman 01-24-2013 08:44 PM
I trimmed out two houses using 4" wide door and window casing with rosettes in the corners and plinth blocks on the bottoms of the doors. The base was also 4" wide.
The casing was simply rounded over and had two grooves. The grooves were fairly close to the edges, so they gave it that up and down and back up look of a flute.
All you need for this is a roundover bit and a "bullet" bit. I think the "bullet bit may be called a bullnose, but that doesn't make much sense.
My trim was white oak, and I spent many hours sanding by hand. I got into those grooves with something like a 3/8" piece of pipe with sandpaper coiled around it. There just is no simple way to do this, no easy button.
This is why I would urge you towards a double, round bottom groove instead of the flutes. It will be nearly impossible to sand those flutes. And has been pointed out, you will need a planer head and knife to make them.
By the way, my base was a simple round-over as well, and I went block to block with it.
The trim package was best described as "craftsman". The stock was 7/8" thick, so you really had some depth.
joecaption 01-24-2013 08:45 PM
Not worth all the bits and time to make one, just buy it already made.
It's called fluted not beaded.
http://www.houseoffara.com/products/...-mouldings/all
Bradeno 01-24-2013 09:08 PM
Its is for the end cap on a back wall of a tiled shower and tub that has an open closet behind it. The shower backwall is double plastered thick on the nonshower side.
The width of 5" is the tile thickness plus the stud plus the plaster.
Cant find any trim of that width premade.
joecaption 01-24-2013 09:14 PM
Got a picture of where it's going to go?
Bradeno 01-24-2013 09:52 PM
2 Attachment(s)
Here is the shower and a closeup of the 5" wide end cap I am trying to cover in my bath reno.
I think Menards has something that will work, prefab, but it is MDF, so I have no intention of using it next to a shower. Other than that, I believe the widest they come are 5" or 5.5"
Also, I was just planning on using a pine 1X6, ripping it to 5", routering it for the bead/flute/roundover pattern, and painting it white.
Bradeno 01-24-2013 09:54 PM
Oooh, that pointed roundover bit might work. What do you guys think?
They don't sell anything that at the Menards here or True Value.
Any other creative ideas? Could I somehow use a 4" premade casing and do something to the 2 outside edges that would look nice? That house of fara site doesn't show any 5" rounded flutes.
Damn.
oh'mike 01-24-2013 10:03 PM
https://encrypted-tbn1.gstatic.com/i...4AG28WrpfwKFWA
oh'mike 01-24-2013 10:07 PM
You need a shaper like the one in the picture above---
I suggest to also look at exterior PVC trims---there are many available for trimming out pillars and doors that look similar to the one in your link--in wider widths---
Bradeno 01-24-2013 10:36 PM
The sahper looks pretty complicated and I have never used one. Any good explanation of what a shaper is and how it works? I doubt that is feasible for this project :)
*Will the pointed round over bit on a router work? This seems like the simplest option
Also, could you link me to the PVC trim you were thinking might work.
Would it look as classy as wood? I have never used outdoor trim inside.
