Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-21-2011, 09:55 AM   #1
Question
how to build toy shelf near ceiling of kids room
Hi, i'm new here. I hope i'm posting correctly. I would like to put a shelf around the whole perimeter of my childs room. the shelf would be high on the wall, near the ceiling (except she has catheral ceiling so its not really near the ceiling but would be in a room with regular height ceilings) and basically just a flat shelf board with wooden, ready made supports underneth. I can figure out all the problems like making the miter cut in corner where boards meet and supporting the shelf board with the bracket boards underneth, but what eludes me is how the corners will be supported. I don'tthink there would be a bracket under there in the corner...i don't know. is it just that I'd have the brackets NEAR the corners and the boards just well supported for the weight that would meet in the corner? any ideas? thanks. oh, and also i'd put a molding just under the board shelf for a finished look and added support i'm sure.
Kimmoski is offline   Reply With Quote
Old 06-21-2011, 10:08 AM   #2
Super Moderator
If you use butt joints instead of miters,the joint could be held together with dowels--a spline--biscuit-or a support piece screwed above or below at the joint.
Old 06-22-2011, 08:22 AM   #3
You'd put the support brackets as close to the corner as possible and use Mike's shelf connection suggestions.
Ron
B. Franklin 1759
Tags
ledge, shelf
How can I build shelf for microwave 68MHJCs Carpentry 11 02-15-2011 08:20 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Lowering Ceiling in Great Room etabbert Remodeling 3 02-27-2010 10:00 PM
Hanging shelf (mini "loft") from finished garage ceiling bdr Carpentry 6 11-30-2008 11:31 PM
Builder skipped ceiling joists in bonus room need advice minicus Carpentry 31 08-11-2008 11:44 PM
