How To Build An Arched Exterior Door Jamb - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-25-2014, 10:01 PM   #1
how to build an arched exterior door jamb
I have built exterior jambs before. I have never built an exterior arched jamb though. Could I get some tips from someone that knows there stuff.
buildersam is offline   Reply With Quote
Old 06-25-2014, 10:51 PM   #2
Rewards Points: 990
Well sam, after some controversy and discussion today about what's allowed on the forum I'll just say there is some information on google because I'm confused. Just don't waist your time on eHow.
Old 06-26-2014, 06:08 AM   #3
DIY staff
Rewards Points: 7,174
Posting links is allowed--but a cut and paste is not ---MODERATOR
What exactly are you trying to do? What wood? What tools do you have access to?
Paint grade or stained?
Old 06-26-2014, 06:19 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
you cut little kerfs in the top side of top jamb spaced about 1" apart and 1/8" or 3/16th deep to get the bend or use a bendable product like cpvc or flex mould/ trim...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
oh'mike (06-26-2014)
Old 06-26-2014, 06:35 AM   #5
DIY staff
Building an arched clamping template and laminating several layers of thin stock (using exterior glue) is a safe way---takes a lot of clamps---
Old 06-26-2014, 07:16 AM   #6
kwikfishron's Avatar
Rewards Points: 378
I've used heat to bend Azek (PVC) a few times now with good results, it would be prefect for an exterior frame imo. More time goes into the templates than the bending itself.
This video shows you the process I've used. They sell "Heating systems" that are pretty slick (and expensive). The poor man method shown in the vid has worked well for me.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 06-26-2014, 09:04 AM   #7
Rewards Points: 78
I recall my dad showing me a couple of the ones that he did as a young man, using a boiling hog kettle and jigs, but that was a few years back, and things change. More recently, I have used hand drive's and Mike's techniques the few times that it has come up. Obviously best to start with some scrap, to get a feel for that bend but don't break median.
Old 06-26-2014, 10:53 AM   #8
Rewards Points: 144
I have done several over the years.I find that the best way is to laminate several thin pieces together using a jig if this is to be stained as finished as Mike suggested.
A lot depends on the type of wood which you did not state.If it's oak this will work well.If it's pine it a little harder.Tell us the type of wood and finish and we can give you a better answer.
mako1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mako1 For This Useful Post:
BigJim (06-26-2014), oh'mike (06-26-2014)
Old 06-27-2014, 09:19 PM   #9
Stairguy
Millertyme's Avatar
Rewards Points: 508
Need to know radius first, that will help determine method to use.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
oh'mike (06-28-2014)
Build up in cast iron pipe bend -> new high pressure toilet to fix? VTJeff99 Plumbing 3 02-09-2012 01:05 PM
How much more would it cost to build another story? reveriereptile Building & Construction 5 01-19-2012 10:51 PM
Basic Deck Build tr7111 Building & Construction 17 01-18-2012 08:38 PM
How do I build this sofft? swt99svt Building & Construction 7 01-17-2012 06:26 AM
Arched Patio Deck Miklo Building & Construction 5 06-15-2009 01:10 PM
