How To Attach Volute To Newel - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-21-2014, 03:30 PM   #1
Rewards Points: 640
How to attach volute to newel
I'm redoing my stairs, and I am doing an over the top rail, right now I have the volute and it's predrilled, I also have an over the top newel which has a matching peg of the same size as the volute hole.
The volute is solid wood, not split or anything like some systems. Do I just wood glue this in place, or is there another way you make the permanent connection between the newel and the volute?
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 07-21-2014, 05:32 PM   #2
Rewards Points: 722
I like gorilla glue where urethane can cushion less than perfect fits.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Thomes (08-05-2014)
Old 08-05-2014, 02:06 AM   #3
In this condition, I had only applied wood glue to the dowels on the volute balusters and newel post and insert them into the holes on the stair treads.
Thomes is offline   Reply With Quote
Old 08-06-2014, 06:57 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
I usually glue and put screw through top of rail into post then plug with a 3/8 bung to match. Have you cut you post to proper height and pitch cut you volute easement?
Millertyme is offline   Reply With Quote
Attach 4x4 post to 2x4 beam? Biggen Building & Construction 12 01-25-2014 08:48 AM
Preparing 1st step for over-the-post starting newel hkeiner Carpentry 9 03-18-2013 12:02 PM
Attaching handrails to newel posts with brackets? CMattox Carpentry 8 02-22-2013 10:43 PM
Adding additional newel post to staircase flamtap Carpentry 3 06-24-2011 08:45 AM
Deck: how to attach stringers 10Thumbs Building & Construction 6 06-08-2011 12:35 PM
