Houses With 48" On-center 4x6 Joists? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2008, 04:26 AM   #16
CT Builder
If I got this correct...
Jury... You asked if adding a layer of 3/8" plywood would be sufficient in your first post.
Since your 1st post you were advised by 3 separate individuals to introduce more framing to the equation.
a full 2 weeks go past
In your most recent post you are now "considering" adding only 1/8" thicker plywood than you had originally asked about, but mention nothing about the framing that was so highly suggested.
What makes you believe that 1/2" plywood is THAT much more of a benefit over adding framing?
All things considered, we all want to get the task at hand completed as efficiently as possible.
At what point do we take someone’s suggestion that has "Been there done that?"
Just my .02, Please reconsider your approach to end at a job well done for years to follow.
Regards,
Daryl
Daryl is offline   Reply With Quote
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 08:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-13-2005 11:16 PM
