Houses With 48" On-center 4x6 Joists? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-10-2008, 01:30 PM   #1
Rewards Points: 79
Houses with 48" on-center 4x6 joists?
I have a 1970s house with 1.125" plywood subflooring over 4x6 joists 48" on center. It's pier and beam over a crawlspace.
How sturdy is this subfloor? Can it handle most types of flooring? Frankly it doesn't "feel" all that sturdy, but it has lasted 30+ years.
I'd like to strengthen it in some of the larger rooms and am wondering if I can just add another layer of 3/8" plywood and then some nail-down hardwood flooring. Is this sufficient?
juryduty is offline   Reply With Quote
Old 03-10-2008, 01:42 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,...
I think you'll get more bang for the buck by closing up those 4' Centers.......
How about a run of 2X6s to bring it to 16" or 24" centers,..??
Old 03-10-2008, 03:19 PM   #3
Rewards Points: 79
Here's a picture
Old 03-10-2008, 04:19 PM   #4
CT Builder
i like Bondos idea filling in the "16 OC's" with 2x6.
prior to installing the 2x6 i would mark my layout and install hangers on one side of the bay. next i would suggest a bead of subfloor adhesive on the top of each 2x6 to be installed. Install hanger on remaining end of each joist as you install them.
-Daryl
Daryl is offline   Reply With Quote
Old 03-10-2008, 04:22 PM   #5
CT Builder
or... if you so choose to run your 2x6 joist perpendicular to the subfloor (as you should)
hang a dbl 2x6 at each post that the 4x6 is sitting on, and then hang your 2x6's on the dbls
and DONT FORGET to insulate vapor barrier up if there is living space above.
Old 03-10-2008, 04:23 PM   #6
Rewards Points: 79
Ok
So I should run 2x6's perpendicular to the existing joists, without any additional footings (can't easily pour new concrete footings anyway). How many 2x6's should I run? Every 2' or so?
Old 03-10-2008, 04:51 PM   #7
CT Builder
at each post that post down the beam to the footing... install a dbl 2x6 joist on the beam. Then install dbl hangers on each end. then measure from the beam 16" and make a mark, then 32", then 48" then make an X on the side of your 16" mark that is closest to the beam. square this mark on the beam with a speed square or combo square. then install the joist on the X so there will yield a spacing of 14.5" in between the beam and the joist.
-Daryl
Old 03-10-2008, 05:26 PM   #8
Rewards Points: 5,336
Where do you live that this construction would be to code?
Ron
Old 03-10-2008, 05:38 PM   #9
Rewards Points: 79
In the San Francisco Bay Area (East bay). The house is part of an 1000+ home development built in the 1970s. Is it considered "cheap"?
Old 03-10-2008, 05:46 PM   #10
California probably currently has the strictest structural requirements in the U.S. Maybe the '70's were a little more mellow.
Ron
Old 03-10-2008, 05:52 PM   #11
Rewards Points: 1,274
Is the entire house like this, or is this an addition. That work doesn't look like it's 30 years old.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-10-2008, 06:02 PM   #12
Rewards Points: 79
The entire house is like this. The house was built in 1972. You're right, it doesn't look 36 years old and has held up well. The problem is that if you're standing in a room and someone walks by you at close range, you can feel the plywood span give a little bit. This is what I'm trying to fix -- I want to make it feel sturdier and hold up under hardwood or laminate, maybe tile, etc.
Old 03-10-2008, 06:21 PM   #13
General Contractor
joasis's Avatar
I just thought I have seen everything.
As suggested above, add joists.....and if it wasn't clear from above, the easiest way to tackle this would be to run them 90 degrees to the main joists...that makes the added joists like 44 inches long, and if you do 16 or even 24 on center, it will add a lot of rigidity to the floor. Looks like you have plenty of room to work in.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 03-24-2008, 01:06 PM   #14
I have the same problem in the addition that was built on my house. The addition was put on about the same time that your house was built. The rest of my house looks exactly like yours underneath, but my subfloor is 2"x6" T&G, and is VERY strong, with no flex.
My addition, however is the same specs as your house, including the plywood (called plyscord back then), but they DIDN'T put piers in to support the span. It is 11'6" by 23'. My 4x6 beams span the 11'6", with no support in between!
MY question to everyone is can I jack up the now-sagging beams and put posts and pier footings underneath?
They only sag about 1/4" - 1/2", which has caused a slope in my floor. Whille under there, I want to add the 2x6 joists mentioned earlier to eliminate all of the flex in the subfloor, as I am going to do 16"x16" porcelain tile in one area of the addition.
Also, underneath the addition is the original concrete patio that was the backyard. Will I be able to set the pier footings right on top of this concrete?
I ask the stupid questions.....but I expect the smart answers.
Wanttodoitright is offline   Reply With Quote
Old 03-25-2008, 01:59 AM   #15
Rewards Points: 79
I am considering simply adding another layer of 1/2" plywood, screwed and glued to the floor, then a layer of nailed hardwood. Can you folks really tell me that this would not strengthen the floor considerably? It seems like an easy, straightforward fix. The problem is the span, right? And this strengthens the span a lot.
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 08:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-13-2005 11:16 PM
