-   -   Hot Tub Cabinet (Surround) (http://www.diychatroom.com/f14/hot-tub-cabinet-surround-150753/)
pettit0408 07-19-2012 12:41 AM
I got a hot tub from a friend and the tub is fine but the cabinet rotted pretty bad. Luckily I was able to salvage the measurements from the old cabinet. I've never built one of these things and parts of this were too rotted for me to see how accurately it went together. The spa manufacturers don't make replacement cabinets. They figure by the time it rots, you're gonna buy a new one. Anyone done one of these before?
oh'mike 07-19-2012 07:24 AM
Yep----However---in order for one of us to help---we need help from you--
Post a picture----also a link to a cabinet similar to the one you like----and a few dimensions.
There are a lot of members here that will jump right in when you add those missing elements.-Mike---
pettit0408 07-19-2012 08:52 AM
http://images.craigslist.org/5I15N85...943c7b15b9.jpgOK so we got a 4 seater Jacuzzi Echo. Plain little tub but just what we want as a starter tub before we decide to take the plunge and spend 5-10K on a new one. Here's the specs from the owners manual:
Model 310
DIMENSIONS
75" (1905 mm) L
69-1/2" (1765 mm) W
30" ( 762 mm) H
PRODUCT
WEIGHT
307 lb
(139 kg)
ELECTRICAL
REQUIREMENTS*
115 VAC, 15 AMP, 60 Hz
Requires Dedicated
Separate Circuit
Equipped with GFCI
Incorporated in Line Cord
OPERATING
GALLONAGE
220 U.S. gal
(833 liters)
TOTAL WEIGHT/
FLOOR LOADING
2741 lb (1246 kg)
77 lb/sq. ft. (376 kg/m2)
****Hope this helps*****
And thank you!
woody4249 07-19-2012 01:22 PM
I guess it depends on how ornate or involved you want it to turn out to be.
I would keep it simple. Build a 2x4 PT four sided frame for it to sit on. If it goes against a wall or corner then the frame will be the same but the facings will be less work. Install a cap mitered in the corners at the 2x4's so that it will overhang the panels by 3/4". Add a drip groove to the underside of the cap, like you would see on an outside window sill. Check where you need access to the pump etc and design the access panels around that.To make it really simple, the entire side could come off for access in one piece.
I would use 1x3 or 1x4 cypress or cedar T&G V'd boarding installed vertically. Use stainless steel nails and a coat of tongue oil.
Woody
drtbk4ever 07-19-2012 01:49 PM
Hey Pettit, is that the actual tub you were given?
If it is, I don't see much rot. Am I missing something? What I see there should be refinished, but not necessarily replaced.
If you do replace, listen to Woody.
woody4249 07-19-2012 02:13 PM
Holy moly!!.............5to 10 thousand............is that what those things cost new?
You could pretty much buy a workshp of tools for that.....
WHAT ARE YOU THINKING.
I think we will have to have an intervention here ;o)
Woody on cell phone
pettit0408 07-19-2012 11:34 PM
That is a picture of a similar unit. Mine is ROTTED. Pretty bad. I already took most of it apart to see how much damage there was and to pull the guts so I could clean and test them. I wasn't going to sink anything into this if the pump and heater didn't work. But they do, so away we go! This is my test subject here.
pettit0408 07-19-2012 11:36 PM
Woody on cell phone
Woody, I can get a decent one for 3500-5000. But when it comes to my toys, I prefer to buy the Bentley over the Cadillac. This one is more of a rental car than a keeper. My outlook is you can't take it with you and you never know when it's over so enjoy yourself while you can!
oh'mike 07-20-2012 07:07 AM
Woodys suggested method is solid and easy--and will look as good or better than the original---
Common hand tools are all that you need----sounds like a plan----
JulieMor 07-21-2012 09:12 AM
I resided my old hot tub last summer. The siding was okay but I had leaks and the only way to find them was tear the siding off.
http://i867.photobucket.com/albums/a.../hottub_01.jpg
I started with 2x6 redwood lumber and resawed it to match the existing thickness then ran it through a planer and then routered the pieces to match.
http://i867.photobucket.com/albums/a...ottub_02-1.jpg
The pieces are lapped instead of T&G. It's easier to make but for my case, it matched what was there.
This is the old and new side by side picture:
http://i867.photobucket.com/albums/a...ub/old-new.jpg
Before you begin replacing the siding, you might want to check the pumps and other mechanicals. If they are on their last leg, you don't want to find out after you've spent the money residing the thing.
I tore down both pumps and replaced all the seals and greased the bearings. I also replaced the heating elements and installed a new ozonator. I also had to fix several leaks. You need to know what needs fixing before doing cosmetic work.
With the new siding, replacing worn parts, buying new equipment, replacing the top, building new steps, re-foaming, etc., the whole thing cost me about $3K and took a couple of months. But considering the new version of what I have runs about $15K, I'm happy with what I have.
woody4249 07-21-2012 09:26 AM
Very nice job..........I showed it to the Mrs........now she is asking if we can find one like that. Like I haven't got enough to do :no:
GBrackins 07-22-2012 06:59 PM
Woody on cell phone
and don't forget the monthly increase in electric bill to run the pump and heater .... :(
JulieMor 07-23-2012 07:51 AM
Thanks. But if I knew what I was getting into, I probably wouldn't have done it. Finding the leaks was a nightmare. It's solid foam, except in the equipment compartment. I'd find a leak, order the parts, test it, and find there were still more leaks. Then do it all over again.
I saw a used model that was similar, just a bit smaller, for around $4K. But when this whole thing started I didn't plan on spending more then a few hundred to fix the leaks. Then it became a money pit.
woody4249 07-23-2012 09:43 AM
Ha.........know the feeling.....I have a Harley Shovelhead same thing.
It leaks oil so bad that an Arab offered my money for the ground it stood on. :yes:
You can see it on "my albums"
Mike
waiting_in_tn 06-10-2015 02:16 PM
Hot Tub Cabinet Questions
I have a 12 year old spa and the cabinet is about shot. I'd like to replace it with something more maintenance free than the thin redwood that's on it now but I'd also like to work on the frame and replace at least the bottom components with pressure treated wood. However, this tub is pretty big and weights over 450 pounds...anyone have a suggestion for how to get it up off the ground to get to the framing?
Love your responses by the way!
