Im a new homeowner and not the best carpenter, I hope you guys can help. My home front has a trim piece that measures about 1.5x8.75 approx 2 feet from the ground. Alot of it is in bad shape and I wanted to replace it before I paint it. Im not sure what lumber to buy? I thought a 2x10 measured out to 9.25"?? Am I incorrect or is this different? Im not clear what wood to use on the external of a home either? PT? or Douglas Fir, are my only choices without special ordering (as far as I know in Central Cal) in a 2x10. Also, what kind of caulking should be used on outside of house, Ive got a bunch of sikoflex is it ok? Thankyou for any help!
Is this applied directly over your siding?
Also, 8+" isn't a standard width of lumber, so replace in kind, you will need to rip down a 2x10.
Or consider this. Instead of 2x material, which creates a nice ledger for moisture and dirt to cause rot, just use 1x8 Azek. It will be thinner and not as thick, and were it mine, I would bevel the top edge to facilitate drainage.
Applying directly onto the siding isn't a great idea any way you slice it, as moisture will be trapped between the board and siding, promoting rot.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
