Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-07-2011, 05:15 PM   #1
Horizontal drywalling
Do I need to support the drywall between the studs where the top and bottom drywall sheets meet when horizontally installing drywall?
Tobias is offline   Reply With Quote
Old 02-07-2011, 05:19 PM   #2
Experienced
Jackofall1's Avatar
No, not if the studs are spaced at 16" centers.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Tobias (02-07-2011)
Old 02-07-2011, 07:33 PM   #3
Moderator
3/8" drywall needs 16"o.c. perpendicular or parallel, no 24"o.c. studs
http://gypsum.org/pdf/GA-216-2010.html Table #1.
Gary
Clothes taking longer to dry?
Old 02-09-2011, 02:18 PM   #4
Drywall contractor
Absolutely not.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Tobias (02-09-2011)
Old 02-10-2011, 09:08 AM   #5
you should never have to put blocking in between studs for wallboard. I've seen blocking ran to ensure the studs are kept straight, but like mentioned 16 OC is okay for all sizes of wallboard and blocking is not needed or of any benefit. If you have studs that are 24 OC you should always jump to 5/8 wallboard
krw73 is offline   Reply With Quote
Old 02-10-2011, 12:05 PM   #6
No and hang the top sheet first of course after u rock the ceiling
dvatt is offline   Reply With Quote
best way to secure horizontal 2 X 4s.... joetab24 General Discussion 23 12-14-2010 12:56 PM
drywalling 24oc wall 8roty Building & Construction 22 12-21-2009 12:34 PM
Near horizontal to sewer - macerator waste system? vsheetz Plumbing 3 09-29-2009 11:49 AM
Horizontal ground loop questions with geothermal smcmurrey HVAC 1 05-14-2008 11:06 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 07:47 PM
