Horizontal Bannister Railing Height - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 10:17 PM   #1
Horizontal bannister railing height
What should the height be for a horizontal baqnnister railing and a stair railing post to post. Can the horizontal railing be too tall?
murphy1 is offline   Reply With Quote
Old 10-07-2011, 07:11 AM   #2
IRC says 34-38"
Old 10-07-2011, 08:19 AM   #3
kwikfishron's Avatar
Rewards Points: 92
36” min. on the horizontal.
34”min plumb off the nosing for the stairs.
34-38” off the nosing for the handrail.
kwikfishron is offline   Reply With Quote
Old 10-07-2011, 10:53 AM   #4
Registered User
Rewards Points: 4,936
http://www.arcways.com/pdfs/IRC2006.pdf
Gary
Old 10-14-2011, 10:26 AM   #5
Check your local building code. Most areas require 36" min.
yeag6154 is offline   Reply With Quote
Old 10-15-2011, 07:20 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,010
36" inches above finish floor height is standard, once the landing or stairwell opening is over 6' off of the floor it then must be raised to 42" above finish floor height.. now this is in canada for residential. it may vary from country to country and per situation be it residential or commercial
woodworkbykirk is offline   Reply With Quote
Extending height of deck railing tntworks General DIY Discussions 4 03-11-2013 08:16 AM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
Extend height of interior balcony railings by feet? denemante Building & Construction 5 10-23-2010 05:18 PM
Tile under or around a railing? RandyKlein Remodeling 3 06-13-2010 10:08 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 12:19 PM
