Homemade Scribing Tool? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 09:19 AM   #1
Rewards Points: 480
homemade scribing tool?
as I've written about numerous times, trying to scribe the profile of vinyl siding to a piece molding.
in case you need a visual
http://tinyurl.com/2ee7cct
bought a compass from depot for a few dollars, the only one they had in stock. and it's really flimsy and keeps closing/folding when I am attempting to get a line.
is there a better scribing tool that can be homemade?
here's a tool called a power butt that purports to be a better scriber, but it costs $30.
http://tinyurl.com/22lwdum
in the comment section to the video linked above, some said "been using pencil and cotton reel for years… does the same…."
have any of you ever heard of a pencil and cotton reel scriber?
just playing around i put a pencil through a clothes pin and used that to scribe the profile of the siding, not bad to get a line, but i can't control/adjust the distance from the siding to the wood I am scribing to, if that makes sense.
joetab24 is offline   Reply With Quote
Old 08-15-2010, 10:43 AM   #2
DIY staff
Rewards Points: 7,174
Here is a post from next door--Best way to draw a scribe? - Contractor Talk - Professional Construction and Remodeling Forum
Old 08-15-2010, 11:05 AM   #3
Rewards Points: 480
thanks Mike, taking a look.
i was just playing around for a sec w/ the idea of a homemade scribing tool, I made this
http://tinyurl.com/29eudtp
I then put a piece of cardboard up and scribed a line.
http://tinyurl.com/2dyf3vp
http://tinyurl.com/2a3hf92
After cutting on the line, the piece fit but not perfectly.
http://tinyurl.com/2c7v3s7
Not sure I understand why I can’t get a better fit.
Old 08-15-2010, 11:25 AM   #4
Will this work?
http://www.google.com/imgres?imgurl=...1t:429,r:3,s:0
Old 08-15-2010, 12:31 PM   #5
use your finger, or just put the pencil on the flat directly against the siding and slide it down.
while we're at it, are you trying to notch a trim board over the siding? there should be no reason to do this. there should be inside/outside corner pieces for vinyl siding. if it were wood clapboard, just cut the claps back and put the casing in on the flat.
wombosi is offline   Reply With Quote
Old 08-15-2010, 01:06 PM   #6
Rewards Points: 480
"while we're at it, are you trying to notch a trim board over the siding? there should be no reason to do this. there should be inside/outside corner pieces for vinyl siding. if it were wood clapboard, just cut the claps back and put the casing in on the flat."
this is what i am trying to do
do they sell trim already notched, or am i misunderstanding you?
Old 08-15-2010, 02:30 PM   #7
well, they sell inside corner pieces specifically for vinyl siding. it forms a channel on either side that the ends slide into.
in your case it's a slightly different setup, so either proceed as planned, or maybe the trim board can slight into the inside corner piece.
good luck.
Old 08-15-2010, 03:17 PM   #8
Rewards Points: 24
Joe, the compass method should work fine; can you squeeze the joint a bit to tighten it up. I have better ones that I use for closer work, but for things like this, I am still using one that I had as a kid, so it's probably 50 years old, and works well for such projects. You just need to keep the compass level as you scribe.
In the absence of that, you might try flipping your trim piece around, mark the bottom of each high point, then cut a cardboard template that matches the setback, line the template up at each of your marks, and transfer it to your trim. You will probably want to check several of them to make sure that they are the same, but my guess is that they are close enough to be covered by a thin bead of caulk.
Old 08-15-2010, 03:21 PM   #9
Rewards Points: 24
By the way, you don't want to cut it too tight anyway. Even though it appears to be out of the weather, your siding needs to expand and contract, so cut it close, but not tight, and caulk it if needed. I would be inclined to see if it even needs to be caulked first though, because if it is out of the weather, and your cuts are close, you may not even be able to see behind it. That it why they use the channel that schmolze mentioned.
Old 08-15-2010, 06:26 PM   #10
Tom Struble's Avatar
Rewards Points: 2,002
thats a Basswoods scribe
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
oh'mike (08-15-2010)
Old 08-16-2010, 01:10 AM   #11
The rolling power butt will work on curvy surfaces but not well for what you want to do. You might try a woodworking store like Rockler or Woodcraft for a better compass.
hayewe farm is offline   Reply With Quote
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 03:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 07:02 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 01:41 PM
