| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Hang Fiber Cement Fascia Boards
by eHow.com
Fiber cement fascia boards provide the same water protection as other materials but offer increased options for finishes. Since fiber cement tends to be more expensive than other types of fascia, you need to take greater care when you install it. Read More »
How to Plan and Build a Garage
by eHow.com
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
How to Install Barrel Cap Trim
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Barrel cap trim is installed from the bottom up course to course with the panels. Install the end disc, position the first cap on the rig with the rear... Read More »
How to Terminate Shake Tiles over the Gable Fascia
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The shake panels are terminated by bending over the gable fascia at approximately 2 inches. Place the shake cap over the gable aligning a profile in... Read More »
How to Fix a Brick Stair Leak
by eHow.com
If after a rain you notice water collecting underneath your brick stairs, then you may have a brick stair leak. Afraid that you will have to spend thousands of dollars to have your stairs rebuilt? Slow down--this might not be the necessary solution. Read... Read More »
