Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-01-2008, 10:49 PM   #1
Hole in wood door
Is there a quick and easy way to fill a hole in a wood door about the size of a fist?
Sliding Man is offline   Reply With Quote
Old 07-02-2008, 08:05 AM   #2
Hole in wood door
First, some anger management classes to prevent future holes.
Second, hollow core or solid core door?
bob22 is offline   Reply With Quote
Old 07-02-2008, 09:40 AM   #3
Hole in wood door
Quickest, easiest and best looking repair would be a new door.
Old 07-02-2008, 11:06 AM   #4
Hole in wood door
A BIG mirror over a little hole
4just1don is offline   Reply With Quote
Old 07-02-2008, 02:46 PM   #5
joed's Avatar
Hole in wood door
If hollow door and painted then spray foam to fill hole, durabond90 to smooth finish and then a coat of primer and paint.
Old 07-02-2008, 04:25 PM   #6
Jay123's Avatar
Hole in wood door
Yeah, just put your fist back in the hole
Sorry, couldn't help myself.
J
Jay123 is offline   Reply With Quote
Old 07-02-2008, 04:27 PM   #7
Moderator
Termite's Avatar
Hole in wood door
If it is solid, buy a new door.
If it is hollow core and stained, get a new door.
If it is hollow and painted, use a couple strips of lath or paint stir stick and some wood glue to patch the hole from the inside of the door. Bondo can be used to fill in the gap between the face of the door and the lath. Sand and paint and it will be ok looking.
Hollow door blanks are CHEAP. I'd buy a new one.
Old 07-02-2008, 09:43 PM   #8
Hole in wood door
It's a hollow door...very cheap. It wasn't my fist that broke it, but a kong toy that bounced into it. Guess I threw it too hard that time and it hit the door. Thanks for the help everyone.
Old 07-02-2008, 09:48 PM   #9
Jay123's Avatar
Hole in wood door
Shi...stuff does happen. So it's a hollow-core...flat or paneled? And as always, any pics? (i'm a pain)
J
Old 07-08-2008, 11:52 PM   #10
Hole in wood door
Flat. Have a hole!
Old 07-09-2008, 12:02 AM   #11
Moderator
Termite's Avatar
Hole in wood door
Wow, not even a honeycomb door! You sir, are cheap! You could replace the door blank for $30, more or less.
Or, do like I said and slip strips of plywood in there and use Bondo. Then you can paint it.
Old 07-09-2008, 12:35 PM   #12
Hole in wood door
Replacing the door is the best option.If you decide to use Bondo, take the door outside. Bondo is best used in a well ventilated area.
Handyman Jim Noonan is offline   Reply With Quote
Old 07-09-2008, 08:54 PM   #13
liscenced electrician
Hole in wood door
i wouldn't use bondo in that, it would probably crack out
jimmy21 is offline   Reply With Quote
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 01:24 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 06:36 AM
Fixing a wood door... CuCullin Carpentry 6 10-27-2007 07:46 PM
Hollow wood door with hole where the hing plate goes earlc General Discussion 4 07-08-2007 02:21 PM
