-   -   Hole in wood door (http://www.diychatroom.com/f14/hole-wood-door-23072/)
Sliding Man 07-01-2008 09:49 PM
Hole in wood door
Is there a quick and easy way to fill a hole in a wood door about the size of a fist?
bob22 07-02-2008 07:05 AM
First, some anger management classes to prevent future holes.
Second, hollow core or solid core door?
jogr 07-02-2008 08:40 AM
Quickest, easiest and best looking repair would be a new door.
4just1don 07-02-2008 10:06 AM
A BIG mirror over a little hole
joed 07-02-2008 01:46 PM
If hollow door and painted then spray foam to fill hole, durabond90 to smooth finish and then a coat of primer and paint.
Jay123 07-02-2008 03:25 PM
Yeah, just put your fist back in the hole :laughing:
Sorry, couldn't help myself.
J
Termite 07-02-2008 03:27 PM
If it is solid, buy a new door.
If it is hollow core and stained, get a new door.
If it is hollow and painted, use a couple strips of lath or paint stir stick and some wood glue to patch the hole from the inside of the door. Bondo can be used to fill in the gap between the face of the door and the lath. Sand and paint and it will be ok looking.
Hollow door blanks are CHEAP. I'd buy a new one.
Sliding Man 07-02-2008 08:43 PM
:laughing: It's a hollow door...very cheap. It wasn't my fist that broke it, but a kong toy that bounced into it. Guess I threw it too hard that time and it hit the door. Thanks for the help everyone.
Jay123 07-02-2008 08:48 PM
Shi...stuff does happen. So it's a hollow-core...flat or paneled? And as always, any pics? (i'm a pain)
J
Sliding Man 07-08-2008 10:52 PM
Flat. Have a hole! http://img60.imageshack.us/img60/623/holeqd8.jpg
Termite 07-08-2008 11:02 PM
Wow, not even a honeycomb door! You sir, are cheap! :wink: You could replace the door blank for $30, more or less.
Or, do like I said and slip strips of plywood in there and use Bondo. Then you can paint it.
Handyman Jim Noonan 07-09-2008 11:35 AM
Replacing the door is the best option.If you decide to use Bondo, take the door outside. Bondo is best used in a well ventilated area.
jimmy21 07-09-2008 07:54 PM
39 Attachment(s)
i wouldn't use bondo in that, it would probably crack out
