Hitachi C12LSH For Baseboards And Crown Moulding? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 10:37 PM   #1
Hitachi C12LSH for Baseboards and crown moulding?
Hi,
Have any of you used the Hitachi C12LSH or C12FDH? I need to buy a saw asap (preferably tomorrow if everything goes well) for 4" crown and 6" baseboards.
I posted here before about getting a Performax miter saw (and was dissuaded from doing so) for this and have since run into a C12LSH at a pawn shop for $225. I was about to snatch it up, however I hear bad things about wobble in the blade on the saw.
Can you guys recommend this saw for this fine woodworking or no?
I could also get the C12FDH from Menards this week, new for $200.
Will both these saws be ideal for this task? Should I avoid the LSH or will it do a good job if I am gentle with the saw? If so, will the 12" FDH do a precise job?
I really don't want to screw up these last fine touches on this remodel that I have to sell.
Thanks!
Bradeno is offline   Reply With Quote
Old 01-21-2013, 10:58 PM   #2
Rewards Points: 13,458
The C12LSH is in my opion one of the best saws made. Only problum is it's super heavy.
I mounted mine to a Ridgid miter saw stand and have a trailer with a landscape gate to get it around but I would not want to be moving this around every day in the back of a truck.
http://www.bing.com/images/search?q=...electedIndex=0
Old 01-21-2013, 11:04 PM   #3
I don't care if it is heavy; it looks like a tank, I expect it is heavy.
Do you find that it is square with the fence and not wobbly and have you used it for precise finishing cuts like crown?
Which part(s) would likely be the culprit(s) if there is some wobble in the blade as there appears to be?
http://www.ereplacementparts.com/hit...297_13306.html
Here is a blowout of the saw.
Thanks for your response!
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 09:15 AM
How to match mis-matched crown moulding tooladdict Carpentry 5 10-13-2011 10:55 AM
Crown moulding and drywall (to tape or not to tape?) gspck Drywall & Plaster 4 11-10-2010 02:41 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 10:52 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 10:41 PM
