Hinges For A Linen Closet I Built Myself - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 03:17 PM   #1
Rewards Points: 28
hinges for a linen closet i built myself
i recently built a basic cabinet using plywood and 1x2 and 1x3s for a face frame, ive come to learn that i need a specific type of cabinet hinge as i did construct a face frame but not sure whether i want a european style or more of a standard style hinge. id rather not have to drill into the cabinet door so if i go european style id like the mortise free tyoe but does anyone have input on which kind to buy?whats easier to instsll? any tips would be appreciated too!
dmack7 is offline   Reply With Quote
Old 01-24-2012, 03:18 PM   #2
Rewards Points: 28
Old 01-24-2012, 03:22 PM   #3
Rewards Points: 79
What kind of doors are you installing? Inset? Offset? Overlay?
Dwillems is offline   Reply With Quote
Old 01-24-2012, 03:24 PM   #4
Rewards Points: 28
over lay
Old 01-24-2012, 03:25 PM   #5
Rewards Points: 28
not sure what I'm using to make the fire yet either, they are kind of big i may have to cut more plywood ad they will be 15 3/4 wide
Old 01-24-2012, 03:57 PM   #6
Rewards Points: 2,210
any styles that are adjustable, which make installation easier as you can be a little off then adjust it in the hinge.
mae-ling is offline   Reply With Quote
Old 01-24-2012, 06:37 PM   #7
Retired carpenter
The easiest ones to install are the ones you screw on the face of the cabinet and the back of the doors.
abracaboom is offline   Reply With Quote
Old 01-24-2012, 06:41 PM   #8
Rewards Points: 324
Lee Valley has a HUGE selection of cabinet hardware if you're also looking for a place to buy.
www.leevalley.com
gma2rjc is offline   Reply With Quote
Old 01-31-2012, 10:32 PM   #9
Rewards Points: 28
turned out pretty good
Does a swinging/sliding closet door hybrid exist? thewestcoast Windows and Doors 17 08-20-2013 03:43 PM
Closet motion lights gmhammes Electrical 24 03-03-2011 08:53 AM
Mold starting in linen closet Zee 32 General DIY Discussions 4 01-24-2011 04:56 PM
Closet door options gmhammes General DIY Discussions 2 01-05-2011 04:47 PM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 09:36 PM
