Hinged Bar Top - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 01:21 AM   #1
Wench's Avatar
Rewards Points: 109
Hinged bar top
We are remodeling our 50's basement, the bar is square and had a door that opened to get behind it but the top never flipped up...yep, you had to crawl under it. We cut and hinged it to make a flip top but it is very heavy, is there something like a shock/cylinder (not sure what to call it) to put under it to help lift it and/or slow it down so if it gets bumped it won't slam or take someone's fingers off.
Wench is offline   Reply With Quote
Old 01-25-2014, 09:22 AM   #2
chitownken's Avatar
Rewards Points: 510
Look for spring loaded hinges that would fit the thickness of your bar top.
chitownken is offline   Reply With Quote
Old 01-25-2014, 09:50 AM   #3
Wench's Avatar
Rewards Points: 109
That's part of the problem, the top is finished. I think they used piano hinges and it open and closes o.k. It's just very heavy.
Old 01-25-2014, 10:15 AM   #4
bbo
spring loaded piano hinges? look those up.
bbo is offline   Reply With Quote
Old 01-30-2014, 04:35 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Nobody has found a spring loaded hinge to solve this problem which was solved back even before the middle ages with the invention of using a counterweight to raise the Drawbridge.
Amazon doesn't sell a counterweight for your bar section but you can make your own DIY model using:
1.Steel cable
....http://www.amazon.com/Master-Lock-67...ds=steel+cable
2. A Pulley sized for above cable
3. Window cast iron or lead Sash weight or equivalent.
Directions:
1. Connect end of cable to top side edge farthest from hinge.
2. Mount the Pulley to a position above the bar.
3. Adjust cable as required and connect to sash weight.
4. Adjust number of sash weights as needed for easiest up/down.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-30-2014, 10:10 AM   #6
Wench's Avatar
Rewards Points: 109
Thank you PaliBob, I think that may be the only way to solve lifting the heavy flip top.......but I think we will just leave it as is for now.
Now I'm thinking about cutting the existing door in half and making swinging doors. I'm not sure if that can be done because its knotty pine.
Old 01-30-2014, 11:10 AM   #7
Rewards Points: 12,808
Posting a picture of it may help.
Old 01-30-2014, 09:25 PM   #8
Wench's Avatar
Rewards Points: 109
I'm not sure how. Do I need to use Photo-bucket, or can I just attach from my pictures?
Old 01-30-2014, 10:50 PM   #9
Wench's Avatar
Rewards Points: 109
I looked up how to post pictures so I made an album but I haven't figured out how to post the pic on a thread yet....but I'm working on it.
Old 02-01-2014, 01:37 PM   #10
Wench's Avatar
Rewards Points: 109
testing to see if picture will post
Old 02-01-2014, 01:46 PM   #11
Wench's Avatar
Rewards Points: 109
It worked! I was having a problem copying the code with my I-pad, It works fine from my laptop. Here is another pic with the door put back on. Sorry for all the posts, I'm sure it bores the people that are familiar with this site...as you can see I'm new.
Old 02-03-2014, 10:07 AM   #12
Tool Geek
PaliBob's Avatar
Hinge CounyerweightThis
This is what my idea of a Counterweight would look like.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-03-2014, 11:10 AM   #13
Wench's Avatar
Rewards Points: 109
LOL As lovely as that looks its hooked up wrong. The flip top opens/lifts on the right.
Old 02-03-2014, 05:34 PM   #14
Tool Geek
PaliBob's Avatar
* Pulley and Sash Weight not shown.
* Shown is ceiling slit for movement of cord weight
* The Sash weight cord does have be steel cable
* The counterweight pulley needs to be mounted as close as possible to the top of the steel support column.
Disclaimer
& Stay Safe
.....Bob Lavery
Andersen Double Hinged French Door Problem tconway Building & Construction 24 06-05-2016 08:30 PM
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General DIY Discussions 12 05-02-2013 11:39 AM
Hinged shower doors more expensive than sliding shower doors? darsunt Remodeling 8 03-07-2012 09:11 PM
Replacing standard sliding glass door with same size fixed on side hinged second side Jacey Windows and Doors 2 12-08-2011 07:13 AM
Microwave with right hinged door stan 41943 Appliances 2 03-24-2008 10:23 AM
