Hinge Stops Door From Closing - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 04:25 PM   #1
hinge stops door from closing
Replaced a steel door on a condo today with a fiberglass slab. Cut door to fit opening, shimed bottom to set in opening, marked existing hinge mortices, removed door and using hinge jig routed in new spaces. Installed old hinges and hung door. Door fits opening well but last 1-2 inches of closing causes hinge to move and you have to apply slight force to close door. Messed with shimming for couple of hours but still have same issue. Will take belt sander back tomorrow to see in hinge side is not true. any other advice
rhcube is offline   Reply With Quote
Old 09-27-2010, 05:54 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... Sounds like the hinges are mounted inside, out....
Old 09-27-2010, 07:00 PM   #3
the Musigician
DangerMouse's Avatar
Yup, most hinges only go on one way.
Remove hinge, close it so it's flat, then remount it that way.
Po)
DM
Old 09-27-2010, 09:36 PM   #4
remodeling pro
I don't suspect hinges mounted backward, that is pretty obvious since the screw holes are countersunk. If the hinges are mortised deep enough to be flush, and the screws are driven straight so that all of the heads are nice and flush; I'd put my money on the door jamming on the weatherstripping. Remove the weatherstripping from the hinge side and try the door.
troubleseeker is offline   Reply With Quote
Old 09-27-2010, 09:49 PM   #5
the Musigician
It could also be as simple as a screw that did not get screwed all the way in.
DM
Self closing hinge removal azhomeowner Remodeling 5 08-07-2012 02:59 AM
Extending finished attic insulation stops? Mitch H HVAC 2 12-09-2009 12:00 PM
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 01:40 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 12:00 PM
