-   -   hinge stops door from closing (http://www.diychatroom.com/f14/hinge-stops-door-closing-82484/)
rhcube 09-27-2010 03:25 PM
Replaced a steel door on a condo today with a fiberglass slab. Cut door to fit opening, shimed bottom to set in opening, marked existing hinge mortices, removed door and using hinge jig routed in new spaces. Installed old hinges and hung door. Door fits opening well but last 1-2 inches of closing causes hinge to move and you have to apply slight force to close door. Messed with shimming for couple of hours but still have same issue. Will take belt sander back tomorrow to see in hinge side is not true. any other advice
Bondo 09-27-2010 04:54 PM
Ayuh,... Sounds like the hinges are mounted inside, out....
DangerMouse 09-27-2010 06:00 PM
Yup, most hinges only go on one way.
Remove hinge, close it so it's flat, then remount it that way.
Po)
DM
troubleseeker 09-27-2010 08:36 PM
I don't suspect hinges mounted backward, that is pretty obvious since the screw holes are countersunk. If the hinges are mortised deep enough to be flush, and the screws are driven straight so that all of the heads are nice and flush; I'd put my money on the door jamming on the weatherstripping. Remove the weatherstripping from the hinge side and try the door.
DangerMouse 09-27-2010 08:49 PM
It could also be as simple as a screw that did not get screwed all the way in.
DM
