Hinge Door Stop - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 02:42 PM   #1
Hinge Door Stop
Can anyone tell me how to solve my problem?
The only option i have on a few of my doors is a hing door stop. The problem is that all the pins are completely covered with no gaps and each end are screws that cover the pin area thus I cannot use the hinge stops that i have seen available.
any help or ideas would be greatly appreciated.
volhardware is offline   Reply With Quote
Old 02-20-2009, 10:20 PM   #2
Registered User
Termite's Avatar
You should be able to easily get replacement hinges that have removable pins. If your hinges' pins aren't removable then the hinge pin doorstops won't work for you...If the pin comes out you don't need a gap. The stop sits on top of the hinge under the head of the pin.
Self closing hinge removal azhomeowner Remodeling 5 08-07-2012 01:59 AM
Stripped out door hinge screws krankykitty Carpentry 23 01-16-2012 09:23 PM
Hinge bits slipping winner155 Carpentry 6 10-19-2008 07:40 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 11:00 AM
