Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-09-2009, 06:36 PM   #1
Default Hiding cables
Ok guys here's the script.
Done plenty of tv wall mounts for myself, but never come accross this prob.
I'm going to wall mount on top of the mantle piece, and bring cables down to the right hand side of mantle piece, in behind the plasterboard, to meet with cabinet on the floor. How do I get passed the joists? Since it's not a vertical cable drop, which is basic, how do you overcome this obstacle of attempting to pass cables through joists. Surely, there is an answer, without bursting open the plasterboard.
Cheers!
Lutron_boy is offline   Reply With Quote
Old 10-09-2009, 07:30 PM   #2
If I understand your problem, one solution:
http://www.idealindustries.com/produ...drill_bits.jsp
bob22 is offline   Reply With Quote
Old 10-10-2009, 04:40 PM   #3
+1 on the flex bit. You might have to cut a few holes to run the wires but as least you dont have to full blow take down all the plaster.
Holt is offline   Reply With Quote
Old 10-11-2009, 02:53 AM   #4
Household Handyman
Another vote for the flex-bit. I have one and it's saved my behinny more times than I can remember. Of course I'm 60 now so I can't remember much anyway. Thanks, David
More On This Topic
What is an I-Joist?
What is an I-Joist? by Expert Village
This is Ben Ingham with Expert Village talking about a walk out basement. Once we get this wall corrected whatever problems and however we can go about getting it corrected and then the next step in the next procedure is to be sure it is reinforce and it... Read More »
Hi, I am Drew Fendy here today to demonstrate how to install a jack for your telephone for ExpertVillage.com. Now we are going to talk about the equipment that you need to install your phone jack. We have a choice if it is just going to be a regular... Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Back in our room and now we've got our California closet system installed, we have one panel that's not painted, that we didn't have a backer board put on, so we can put the wall color behind it, in front of this will be the TV, which is, I think forty... Read More »
Hello! My name is Tony Ramirez from Tampa, Florida and on behalf of Expert Village, this is do it yourself home security systems. Let's get started. A more advanced but great thing to have in your home is a security camera. These can be purchased from... Read More »
RG-6 near electrical cables Randell Tarin Home Theater 8 10-12-2008 05:23 PM
routing cables through walls and attics cannouu Electrical 18 04-10-2008 08:53 PM
Hiding equipment for wall mount LCD themode Home Theater 21 03-13-2008 09:48 AM
Help! Need way to locate low voltage light cables Johnboy555 Electrical 15 01-03-2008 09:01 PM
Help! Need way to locate low voltage light cables Johnboy555 Landscaping & Lawn Care 2 01-02-2008 04:39 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
