Hide Deck Board Ends - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-06-2007, 07:31 AM   #1
Hide deck board ends
Does anyeone have a good idea to hide ie.. make a nice clean edge for wood decking? I don't want to use a facia board as I have multi level step downs w/ lights. I'm looking for something like "L" molding that is thin and can be put over the edge to hide the ends of the decking. Any suggestions??
bardad1022 is offline   Reply With Quote
Old 06-06-2007, 08:09 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I am not sure that I follow you about the exact area that you are writing about.
Here's a picture, can you use this to describe more in detail what you are referring to?
http://i28.photobucket.com/albums/c2...T/DSC01753.jpg
- Build Well -
Old 06-06-2007, 08:59 AM   #3
Rewards Points: 264
You would have to install blocking between the joists then run a 2x perpendicular to the deck boards.
Jeekinz is offline   Reply With Quote
Old 06-07-2007, 10:14 AM   #4
Rewards Points: 768
Wouldn't you need to drop your joist hangers an 1 1/4" so that the joists will sit lower. Then when you add your decking, it will be level with the ledger and rim joists?
cibula11 is offline   Reply With Quote
Old 06-08-2007, 09:55 AM   #5
Rewards Points: 264
Good Tip!
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Deck Board Gap? cibula11 Building & Construction 22 06-25-2007 11:11 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
