Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-29-2009, 02:39 PM   #1
Default Hidden hinges for 1/2" doors
Are there some good euro hinges for cabinet doors that are only 1/2" thick? These doors were made from scraps, and turned out a little thinner than usual!
patcrisp is offline   Reply With Quote
Old 08-29-2009, 03:34 PM   #2
Building codes guy, Mod
thekctermite's Avatar
I'm not aware of any cup hinges that will work in a 1/2" thick door. Check Blum's website.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 08-29-2009, 09:23 PM   #3
Perhaps you could fasten a 1/4" plywood block where you want to mount the hinge! Then drill into this!
Old 08-29-2009, 10:14 PM   #4
Remodeler
adpanko's Avatar
I believe most euro cup hinges require a 7/16" deep 35mm forstner hole. If you have a true 1/2" of thickness, you can maybe try to really carefully do only the required 7/16" and not punch through the front. That would require a drill press though to get that kind of depth eveness and accuracy. This is a pretty dangerous idea, but an idea nonetheless.
adpanko is offline   Reply With Quote
More On This Topic
Learn How to Sharpen a Forstner Drill Bit in this free tool care series from our knife sharpening expert. Read More »
Saving money on the energy bill is something every homeowner wishes to do. But what's the best way to go about doing it? One of the first things you should do when you want to create a more energy efficient home is upgrade your existing appliances. Buy a... Read More »
All right, the third thing that you want to think about when choosing a pattern or when designing your own is how many total pieces are you going to have to cut in order to make this pattern work out. And this isn’t only about how much work is... Read More »
Picking a 35mm Camera
Picking a 35mm Camera by Expert Village
A 35mm camera is more often than not what you are going to run into when you are looking at cameras. 35mm refers back to the standard film that is still used today if you were to go out and buy a typical roll of film. It creates images in the 4 x 6... Read More »
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 12:51 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 03:37 PM
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 09:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 07:04 PM
Need ideas for cabinet hinges. wfischer Remodeling 10 01-12-2008 07:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
