Hidden Fasteners For A Large Panel. - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 01:11 AM   #1
Rewards Points: 2,212
hidden fasteners for a large panel.
I am in the design stage of finishing my basement.
In order to have access to the furnace but not have a door in front of it because a door just doesn't work there I am looking at a panel about 92" high and 30" wide.
Wondering about somehow attaching it so it can be removed easily ( 2 times a year). Thinking of using 1/2" birch and fastening it with velcro? Can't think of anything better. would have a 3/4" lip around edges to attach it to.
Any other ideas?
mae-ling is offline   Reply With Quote
Old 11-04-2012, 01:16 AM   #2
Another thought is to use several magnetic door catches.
Old 11-04-2012, 03:16 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
My thinking as well...
This is one that works quite nice....it would let you put a hinge on one side...then to open...push in a little and it pops out.
http://www.rockler.com/product.cfm?p...5&site=ROCKLER
Old 11-04-2012, 07:02 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,358
what about a pocket door
woodworkbykirk is offline   Reply With Quote
Old 11-04-2012, 08:45 AM   #5
A door would look not right here. It's a little alcove about 30" across and 8" deep. wall to keep full area openable.
There is no wall for the pocket door to go into.
Old 11-04-2012, 10:24 AM   #6
Rewards Points: 6,652
Instead of velcro, Rare Earth magnets could work. Otherwise, you would have to use bolts with fasting nuts embedded into the wood frame as another choice.
Old 11-04-2012, 03:15 PM   #7
The rare earth magnets, I would then need some sort of handles to pull the panel off? Panel would fit tight (or close) wall to wall.
Old 11-04-2012, 03:29 PM   #8
Just something to pry it off. You could use a flat putty knife to get in so that you can pull it off with your fingers. They also make handles that you can use that lie flat, but when you lift them, they give you eyes to pull the panel. There are more than one way to skin a cat.
Old 11-04-2012, 03:47 PM   #9
JOATMON
ddawg16's Avatar
Mae....did you look at the item from Rockler? It's a spring loaded magnet. You would not need a handle....push in on the panel...the magnetic pin pushes the panel out.
The Following User Says Thank You to ddawg16 For This Useful Post:
mae-ling (11-04-2012)
Old 11-04-2012, 07:11 PM   #10
Yes I did and it looks like a possible solution.
Wonder how much weight they can hold.
Old 11-04-2012, 09:19 PM   #11
Rewards Points: 636
how about hidden magnetic screws
http://swissinvis.com/
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 11-04-2012, 11:00 PM   #12
That is cool, a little pricey - but totally rad!
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 09:50 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
