Hidden Deck Fastners - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-12-2008, 11:23 PM   #1
Question
hidden deck fastners
Is the Tiger Claw hidden deck fastener a good fastener for 5/4" Southern Pine decking board attachment. I am in the process of planning the reconditioning of an existing deck. I plan on removing the existing 2x6 old, worn decking (keeping the structure) and replacing with new 5/4" decking boards. I would like to attach the new decking with hidden fasteners... access from below is good if needed. Is there another hidden fastener that anyone would recommend over the Tiger Claw brand?
strtiger is offline   Reply With Quote
Old 04-15-2008, 01:40 AM   #2
BuilderRemodeler
deck
Do your homework.
Lots of options.
Lots of opinions.
Most over rated and over priced in estimation of many fine builders.
Tiger Claw sounds and looks like a great idea... the application of it may be fine on smaller Decks.
If the deck is a 800 - 900 square foot deck and if you are dipping into your retirement for your new deck... why you may just find your entire retirement fund is depleted with Mr tiger claw!
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Old 04-19-2008, 08:27 AM   #3
CrossWorks's Avatar
Rewards Points: 150
Also keep in mind, if the framing is not in very good condition, the Tiger Claw is only as good as the strenght of the fibers in the wood. I suspect that your framing may be in question in this case.
Try this product if available down there: http://www.correctdeck.com/products/...cx/default.htm
The fasteners screw down into the framing. Check out the results here:http://www.crossworksme.com/Complete...ble%20Deck.htm
Good Luck!
CrossWorks is offline   Reply With Quote
Old 04-19-2008, 12:31 PM   #4
BuilderRemodeler
Nice Work CrossWorks.
Lot of Work yet a cool effect when all is said and done with the patterns in the decking.
BuilderRemodeler
Old 04-21-2008, 06:43 PM   #5
CrossWorks's Avatar
Rewards Points: 150
Thanks Daryl!
Old 04-23-2008, 03:33 PM   #6
I used 2" galvanized staples on mine.... they're hardly noticeable.
martyshel is offline   Reply With Quote
Old 04-23-2008, 11:25 PM   #7
Custom Deck Builder
BuiltByMAC's Avatar
Crossworks,
Just looked over that project - looks good. One big thing, you DO know that ACQ lumber and aluminum don't play nicely together, don't you? The aluminum strips on the back of your ledger board will corrode and rot away leaving you with ...
And yes, putting spacers behind the ledger board to make it stand off from the house has been done before in many different ways... this would be one -
http://www.deck2wallspacer.com/description.html
Mac
BuiltByMAC is offline   Reply With Quote
Old 07-23-2008, 04:55 AM   #8
Rewards Points: 79
how much are tigerclaw each?
ehoez is offline   Reply With Quote
Old 07-23-2008, 05:53 AM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
They are sold by the box of 90, or bucket of 900. Ther are different types for different kinds of deck boards. Your best bet is to contact a local building or lumber supply house/yard. (FWIW - 90 fasteners cover approximately 50 SF of 5/4 deck boards attached at 16" O.C.)
- Build Well -
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 02:05 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
