Hickory Trim Nail Size Ect. - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 09:06 PM   #1
Rewards Points: 410
Hickory trim nail size ect.
I have never worked with Hickory and plan on trimming out the basement project in it.
I've heard it splits easily so I'm a little apprehensive.
What size nail, ect any tricks to it , any gun better than others ect??
High Gear is offline   Reply With Quote
Old 10-01-2010, 09:25 PM   #2
Civil Engineer
Rewards Points: 4,954
Hickory is very hard, very difficult to drive nails through it. You may need to predrill all the holes. Also consider construction adhesive.
Old 10-02-2010, 08:17 AM   #3
jlhaslip's Avatar
Rewards Points: 2,884
chuck up an electric drill with the same size finish nail as you plan to use and pre-drill
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
BigJim (10-02-2010)
Old 10-02-2010, 10:36 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
A good 18 gauge pneumatic pin nailer. Test on scraps to get the correct pressure setting.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-02-2010, 08:54 PM   #5
Rewards Points: 410
Thanks 18# it is , got to go pneumatic otherwise I'll be blue in the face ( and probably my thumb also) by the time I get through it all.
Good idea practicing on some scraps first for depth but also to get a feel for
it (hickory), probably over thinking it , just don't want to mess it up.
Old 10-03-2010, 11:22 AM   #6
firehawkmph's Avatar
Rewards Points: 1,922
High gear,
18 gauge will be fine for the skinny edge of the molding going right into wood jambs, but you will need something heavier for nailing the thicker edge of the molding where you are going through drywall before hitting the stud. 15 or 16 gauge finish nailer that is up to snuff. Don't use a nail that is way longer than what you need. 3/4" molding + 1/2" drywall, 2" nail would be fine versus 2 1/2". If you're using an air nailer, up the pressure to the upper end of the recommended pressure. Don't go over though.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 10-03-2010, 03:10 PM   #7
Rewards Points: 410
I'm going to be using a mission/craftsman style of trim ( and installation (butt
joints , wrapped exposed ends) so it would be the
same thickness throughout for window and door trim.
The door/window jamb nail will be around a 1/4" from the trim edge so I'm
concerned there , 18# sounds good and heavier nail for the stud. thanks.
Filler diykc Painting 2 01-26-2010 04:06 AM
Differing size of Baseboard Trim offered at the Hardware store pk1023 Carpentry 7 02-23-2009 05:04 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Nail Gun and Compressor - Help! MelindaA Carpentry 7 08-15-2006 08:17 AM
Roofing nail size scarrell Roofing/Siding 3 03-29-2006 11:52 AM
