Help With Window Stool - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 12:38 AM   #1
help with window stool
I recently decided to strip some wood paneling out of a bedroom and skimcoat the walls not realizing I was going to have to remove the window casing. Unfortunatly when I removed the window casing the stool or sill snapped right in half. The windows are replacement windows. If anyone has any ideas I would appreciate it big time.Is there any way to remove the whole stool with out removing the window? I was going to try and drill pilot holes and nail it back on.
SteveBman is offline   Reply With Quote
Old 01-27-2010, 06:21 AM   #2
Remodeling Contractor
just use glue and trim head screws to fix it. Patch the seam and cover the screw heads with putty, sand smooth, prime and paint.
Old 01-27-2010, 10:06 AM   #3
Or you can drill and install Miller dowels.
hayewe farm is offline   Reply With Quote
Old 01-27-2010, 10:42 AM   #4
47_47's Avatar
Rewards Points: 50
Ditto on the Miller dowels
47_47 is offline   Reply With Quote
Old 01-28-2010, 11:54 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
...or, don't hack it together. Rip out the rest of it and pick up a piece of stool board from HD or wherever for like $2. The replacement window only sits against it, not on it, so it doesnt need to come out.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
New and need help w/ window stool Fingersallacct4 Remodeling 3 08-27-2009 05:43 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
window casing stool help? Images posted chinese_lover Carpentry 12 07-23-2008 09:04 AM
