-   -   help with support beams on porch (http://www.diychatroom.com/f14/help-support-beams-porch-2804/)
falcon802 06-19-2006 09:35 PM
I am replacing a porch that has a lot of rott on it, and was wondering if the suports beems that hold up the small roof above are suposed to sit on the porch below with a support beam holding up the porch or do I run the support beams from the bottom of the roof all the way to the ground, then build the porch around them
thank you for any help...
Bruce.
redline 06-20-2006 06:29 AM
You can do it either way.
It is usually easier to build the porch deck first then build the roof section after.
How big is the porch roof? (ex. 10x10, 12x12, 14x14...)
What is the length from the ground to the lower part of the roof?
IHI 06-20-2006 11:35 AM
For us it's easier to build the roof base first and do the porch around it. I like to know the roof will never go anywheres not to mention having to beef up the porch to support the roof load too if going supports ontop of porch.
falcon802 06-24-2006 10:00 AM
thanks guys,
I ended up doing the porch support first then the roof. Worked out great.
Bruce.
