HELP: Sagging Attic Floor - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 12:47 PM   #1
HELP: Sagging attic floor
Hi, I need your advice on our attic floor sagging issue. Please take a look at the photos attached. They are even detached from frames or joists and we do not know what to do... Any of you know how to correct this issue? Thanks in advance.
HELP: Sagging attic floor-img_0103.jpg   HELP: Sagging attic floor-img_0104.jpg
cititravel is offline   Reply With Quote
Old 11-09-2011, 01:00 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Well...unless I'm missing something, that isnt an attic floor. Its the ceiling of the floor below.
My advise would be to not walk on it.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
1910NE (11-09-2011)
Old 11-09-2011, 01:09 PM   #3
Rewards Points: 5,336
Lift the sheetrock from below and support it. The nails should all pop out. Remove the nails.
Make sure the sheetrock is tight to the truss bottom and screw the sheetrock to the trusses every 6-8 ". Then slowly remove the support under the ceiling. Compound all the holes and paint the ceiling.
Ron
B. Franklin 1759
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
cititravel (11-11-2011), DexterII (11-09-2011)
Old 11-09-2011, 01:14 PM   #4
If it is being treated as an "attic floor", that would explain the sagging.
Lucky someone didn't come crashing through if that is the case.
I had a cable installer walk on the "attic floor" in an apartment I had when I was younger. Did the same thing, only worse.
oldhouseguy is offline   Reply With Quote
Old 11-09-2011, 01:30 PM   #5
Rewards Points: 82
Citi, don't dilly dally around up there, or you might end up with sheets of drywall layng on the floor below, but I would do a quick visual in the attic first, just to make sure that no wires, etc. have relaxed and found their way between the trusses and drywall.
The Following User Says Thank You to DexterII For This Useful Post:
Old 11-09-2011, 05:17 PM   #6
DIY staff
Rewards Points: 7,174
Very convenient that there is no insulation.
Jack that drywall up ---now---skip dinner and head to the store for supplies.
Old 11-11-2011, 08:44 AM   #7
I appreciate everyone for replying!
Yes, it is the ceiling of the floor below and we do not walk on it. However, contractors kept walking on them, even though we advised them not to. I guess we should install more pathway, so that no one wants to walk on it any more. As Ron advised, we also scheduled the repair.
Again, thank you, everyone!
Old 11-11-2011, 09:25 AM   #8
DIY staff
Thank you for the response---That happens occasionally-- Not enough nails--not long enough
At least you caught it before it fell----Mike---
Old 11-11-2011, 03:15 PM   #9
Rewards Points: 1,578
where do you live where there is NO insulation in an attic space?
You need some.
bob22 is offline   Reply With Quote
Old 11-11-2011, 04:30 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
during the framing stages its ok to be up walking on the bottom chords of trusses but after drywall is up your just asking for problems.... nothing i hate more than hacker substrades that do stupid things that can compromise framing and interior finish. what these guys should have done is try to run a 2x10 plank up there and set it across the bottom chord so their weight will be distributed across several trusses which will greatly reduce teh chance of screw pops or worse the drywall collapsing
woodworkbykirk is offline   Reply With Quote
Old 11-12-2011, 03:21 PM   #11
Tizzer's Avatar
Rewards Points: 460
My eye sight isn't the best, but when I zoomed in on those pictures - those fasteners looked like tacks. Their shanks look bare.
Tizzer is offline   Reply With Quote
Old 11-13-2011, 01:44 AM   #12
Thadius856's Avatar
Rewards Points: 504
They're perfectly spaced in sets of two, so they look like staples to me. o.O
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 11-13-2011, 07:50 AM   #13
Whatever they are, some screws would help a bunch.
Old 11-13-2011, 12:51 PM   #14
KemoSabe
loneframer's Avatar
They're probably cement coated drywall nails, which are not the problem. The problem is, there appears to be no adhesive used.
I really prefer nailing in some scenarios, primarily because often times screws don't draw the sheet up tight to the joist, or just as bad, compromise the paper, allowing the weight to pull the screw head through.
The double nailing/screwing is industry standard on a ceiling around here. It assures that the sheet is pulled up snugly and will support the weight of the drywall.
For the nails to pull out like that, there is something more going on than weight being applied to the drywall. They should have pulled through the rock before withdrawing from the wood.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
woodworkbykirk (11-13-2011)
Old 11-13-2011, 06:28 PM   #15
yup, double nailing is a method that is used but not often seen. most board hangers that work on homes with wood framing will have teams of 3 workers. 2 guys cutting and tacking sheets then a 3rd who simply follows behind and screws off all the sheets. the guys tacking the sheets will do it with drywall nails. ive done it and its easier than dragging a screw gun when you just putting 6 or 8 fasteners in until it gets screwed off
Return of insulating the side attic floor WillK Building & Construction 4 02-06-2011 12:48 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Insulating attic floor AND rafters? John FX General DIY Discussions 11 10-10-2008 10:50 PM
How do I get from the upstairs attic down to my 1st floor? diyintexas Electrical 8 09-29-2008 05:05 PM
sagging floor - attach LVL? tmenting Building & Construction 3 01-30-2007 01:07 PM
