Help Replacing Window Pane - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 05:11 PM   #1
Rewards Points: 150
we got the frame out of the window and couldn't open the frame up. we busted out the broken glass. now, i need to figure out how to replace the pane.
it seems this will involve disassembling of the frame.
has anyone replaced a pane of glass in this type of window section frame?
here it is: http://img692.imageshack.us/i/img1294zh.jpg/
i'll post photo directly after some editing
rosco is offline   Reply With Quote
Old 02-20-2011, 05:14 PM   #2
Rewards Points: 150
Old 02-20-2011, 05:18 PM   #3
Rewards Points: 150
closer photo
Old 02-21-2011, 05:40 AM   #4
Open the window half way. Pop out the bottom moulding that covers the mechanism (you may have to remove the allen screw that holds in the handle. At the bottom of the sash and at the two sides, are little flat metal slides that hold the metal rods on to the sash. Depress these and slide them off, be careful as the window sash will now be free to fall out!
Reverse these directions to get it back in. Btw, the frame is the part that goes round the whole window. You're talking about the sash.
Couldn't you have just replaced the glass?
mrgins is offline   Reply With Quote
Old 02-21-2011, 08:15 AM   #5
Rewards Points: 150
THX!
the sash, or the pieces of wood holding the window in, seem to go down into the frame. so we removed it to take it to a window shop or glass cutting shop.
anyhow, we got the window out by removing the two side rails. the bars that push the window out have a hinge that allows them to pop off.
i had some neighbors look at this and the sash framework is complicated. i'll see what the glass cutting shop says.
Old 02-21-2011, 08:20 AM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Sounds like you're on the right track
Get it to the glass shop...money well spent since they do this all the time.
...and don't get the neighbors involved...have you seen their place lately?
tcleve4911 is offline   Reply With Quote
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 10:06 PM
replacing window sills denemante Building & Construction 1 09-29-2010 02:59 PM
Replacing a sliding glass door with a new window twildey Building & Construction 1 07-22-2010 08:40 AM
Double pane window installation asuka Carpentry 1 02-06-2007 02:42 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
