Help With Replacing Exterior Window Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 12:12 AM   #1
Rewards Points: 22
Help with replacing exterior window sill molding
Hello all,
I was a little freaked out today to find the wood molding around my kitchen window that faces my yard has heavily rotted away.
All the paint jobs in the past had not covered the surface underneath the molding, and the heavy rains recently did not help. The wood had pretty much broken away in my hand when I pressed on it.
I was planning to remove all the wood surrounding the window and repainting it. I will post some pictures of the damage and the extent of the work desired tomorrow.
My initial questions (please excuse the noob questions, my first time at this):
1. What type of wood should I use to replace this?
2. Should the wood be pressure treated?
3. What type of nails should I purchase?
4. What tools will be necessary?
5. Will I need to cut into any of the interior woodwork?
6. What other preparation should I do before I begin to tackle this job?
Appreciate any help or advice you can give.
nugentoffer is offline   Reply With Quote
Old 03-23-2010, 06:59 AM   #2
I assume you are talking about brickmold molding?? It is not uncommon for that to rot, even when kept painted. It is usually nailed to the window framing and to the house framing, just find the nail heads and start pulling. There will also likely be some caulk that needs to cut away with a utility knife.
Replace with solid vinyl or a vinyl composite, available at home stores, lumberyards. Won't rot, often does not even need to be painted, if you like white.
Old 03-23-2010, 07:08 AM   #3
DIY staff
Rewards Points: 7,174
I think the molding you are talking about is called-'Brick Mold'
That trim as available in white PVC (plastic) --nice--no rot no paint needed--holds nails well.
Buy it at the Depot. Azek is one brand.
The brick molding is actually all that is holding in the window.--(along with the inside trim)
Removing the rotted stuff is a matter of cutting loose any old caulking--and very carefully prying off the bad molding--a chisel is handy to split the old molding at the nails-(if they don't pull out easily)
Once the old molding is gone--remove or cut off any nails that are left.
Miter the new trim to size and nail it in. Caulk with siding caulk at the siding and painters caulk at the window. Fill any nail holes --done
The trim is easy to cut--If you don't have power tools a saw and miter box will work fine.--Mike--
Tom Struble (03-24-2010)
Old 03-28-2010, 05:52 PM   #4
Rewards Points: 22
THanks for all the replies all...
I've removed most of the old wood molding around my window..but I"m having trouble with the paperlike backing that was behind the wood on the sides... please see pictures #1 and #2 below. WHat is this material called? Can I just keep it or should I remove it before I install the PVC type molding?
Should I remove ALL of the old molding? The top and bottom pic#3 and #4 are currently still remaining.
Last question : Read about "drip edges" on some of the DIY sites, do I need to worry about this in my case? Looks like there's already an overhang over my window.
Will head to Home Depot to see what types they have and report back. Thanks.
Old 03-28-2010, 06:10 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
hmmm i think you may have more than a rotten trim issue
looks like ice dam or maybe your gutter is backing up and getting in from behind
or possible a leaking window
you should definitely check this out before installing any type of trim
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
oh'mike (03-28-2010)
Old 03-28-2010, 06:10 PM   #6
DIY staff
That soft pressed board is called Celotex--That is the sheathing---You need to replace that,if its missing.
Here is the typical exterior wall--1. 2x4 studs----2. sheathing(1/2 plywood--OSB---celotex--insulated foam board) 3.vapor barrier
4.siding and trims.
To replace the missing sheathing -I suggest OSB or foam board---for a vapor barrier --felt paper(black tar paper)
If you are putting wood back in there to replace the rotted trims--then the top board can stay.( Modern wood rots very quickly-
paint the back before you install it)
I use Azeks (white PVC trim boards) not real wood--no paint-no rot --A bit pricey but that eliminates doing it over in a few years.
--Mike--
nugentoffer (03-28-2010)
Old 03-28-2010, 06:55 PM   #7
Rewards Points: 22
Tom,
Which picture are you looking at that makes you say this? What part of the trim are you looking at?
Mike, can you chime in on this?
THanks again all for helpful info.
Old 03-28-2010, 07:06 PM   #8
DIY staff
I'll have to let Tom speak for himself--
I'm guessing that he is concerned with the water staining under the window--
That looks like damage from leaking trims and no proper tape and vapor barrier on that area.
Before installing the new trims---there is a special tape used to seal the window flange to the vapor barrier.
Looks like a 3" roll of foil with a tar backing--if the caulk between the window and the trim ever leaks--
any water that gets behind the trim will not get to the framing--Mike--
Old 03-28-2010, 08:38 PM   #9
the old trim rotted out from water intrusion somewhere...no?
if you put new trim on without correcting that your still going to have problems whether the trim is rot proof or not
the stained framing,is a tell tale sign something is wrong,and damage from ice dams or gutter back ups tend to be worse on projecting windows such as bays and bows and box bays which is what you have
or the [what looks like]lack of insulation could be causing condensation on the backside of the trim and framing
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
nugentoffer (03-29-2010), oh'mike (03-28-2010)
Old 03-28-2010, 10:39 PM   #10
Rewards Points: 22
Tom,
Would you suggest that I remove the stained framing studs and investigate the cause of the moisture intrusion? What would I need to look for? I'm not really sure what ice dams are (we don't see a lot of ice here in texas), but my gutters are pretty clean so far.
The removed rotted trim was pretty badly soaked after the last round of heavy rains. I just assumed that this moisture spreaded up the trim and into the framing.
Mike, what brand and model of vapor barrier should I use? What brand and model for the special tape?
Old 03-28-2010, 11:35 PM   #11
sorry about assuming it could be icedams,thats why its important to post your location
Old 03-29-2010, 06:58 AM   #12
DIY staff
For a vapor barrier --use 30# felt paper-( tar paper)---That is tried and true---Tyvek will work --more money -no better in this situation.
I can't recall a brand of tape--it all works well --I never paid attention to the brand.
Paint Crown Molding Before or After Installation? gmhut Painting 28 12-30-2016 06:20 PM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
replacing molding in sunken living room floor lokidawg Flooring 7 08-07-2009 02:41 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
