Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-19-2012, 01:10 PM   #1
Help reattaching refinished stair treads
Hello i pulled up my stair treads and have refinished them and now need to reattach them. They were originally nailed through the top of the tread along the sides and front and then nailed from in behind the riser one step up. I am looking for a way to reattach them with out putting nails through the top as the stain and polyurethane turned out really good. i can screw in through the next riser up and that will hold the back, but i am going to need something on the front. I was considering just using pl400 on the front and sides, but i would prefer not to so that I could pull the treads up again if i ever had to. Another option i thought of was to take off all the risers and put screws in from under neath.
anyone know any tricks for this?
thekingofboggle is offline   Reply With Quote
Old 09-19-2012, 07:52 PM   #2
Is it open under the stringers?
Old 09-19-2012, 09:48 PM   #3
STAFF
BigJim's Avatar
Glue and screw cleats to the side of the stringers, glue and then screw treads through bottom of cleats.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Keith Mathewson (09-20-2012)
Old 09-20-2012, 06:52 PM   #4
Stairguy
Figure 8 fasteners
Millertyme is offline   Reply With Quote
Old 09-20-2012, 06:55 PM   #5
Stairguy
http://www.google.com/url?sa=t&rct=j...lBrRw_9Nm3NNDA
These will work, but I like jiju's plan better
replaced stair treads dhungy Flooring 5 06-20-2012 11:21 AM
Stair treads - wood choice tradeoffs? kidtire Flooring 0 02-01-2012 06:15 PM
What is the correct way to redo stair treads. John/Suz Flooring 5 10-13-2011 09:11 AM
Refacing stair treads Stair newbee Flooring 2 08-10-2010 11:35 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
