Help! Pull-out Pantry Door Is Stuck - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 02:55 AM   #1
Help! Pull-out pantry door is stuck
Hi Everyone,
I am at my wits end trying to work out how to close my pull-out pantry door.
I have the same problem as Nicolushka, namely that my pantry door seems stuck and can only partially close (it has a strange childproof lock(?) on the top as seen in Nicolushka's post):
Request - Help needed for stuck Pantry Slide
Unfortunately, although he found the solution, he did not explain what it was!
Any help from the many experts in this chatroom would be very much appreciated (the pantry door also happens to be blocking my backdoor too)!!!
Newbie2013 is offline   Reply With Quote
Old 01-15-2013, 08:58 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
I am not familiar with that type of slide but from the picture it looks like the gray plastic bar behind the picture of the locks is what locks and unlocks the pullout by sliding forward and backward. If that isn't it you may want to check to see if a screw has worked out keeping the slide from going back in.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-16-2013, 01:14 AM   #3
Thanks BigJim. Yes, the grey slide is supposed to lock/ unlock (I think, according to the illustrations), however, the door slides in part way before jamming no matter what position the grey plastic slide is in. It doesnt seem to connect to anything that I can see although when trying to close the door, something seems to block/ jam the top part of the slide.
Old 01-16-2013, 03:34 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
I would look in the track and see if a screw has worked out a little, those slides are pretty tight.
Jim
Old 01-16-2013, 04:26 AM   #5
I tried looking/ feeling on the tracks to see if there was any blockage. Unfortunately I couldnt detect anything blocking the way (at least not obviously). I dont have ANY experience with these sorts of things, unlike most people on this site I suspect, but just using common sense which usually works although in this case I have to refer to the experts here to try and find the "professional solution"!
Do you think I should try taking the thing apart? I contemplated this idea and hesitate only because I dont know where to start (and the fact that the pantry door is quite heavy)!
Thanks again for your suggestions BigJim.
Old 01-16-2013, 04:32 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
You may have to get someone to help you take the rack off the track in order to see the screws that hold the slide to the unit. Other than being a loose screw, it would be hard to say what it is.
Jim
Old 01-16-2013, 05:18 AM   #7
DIY staff
Rewards Points: 7,174
When the track is pulled all the way out----can you see the screws that attach the track to the cabinet?
If not are there any holes that look like they might be designed for a screw driver to access screws behind the track?
BigJim (01-16-2013)
Old 01-17-2013, 04:18 AM   #8
Hi Oh'Mike,
Yes, I can see the screws through the holes you describe. They look pretty flush"" to me, not protruding unusually far out/ down...
Old 01-17-2013, 06:17 AM   #9
DIY staff
Tighten them anyway----or remove the whole track so you can study it and figure out what is hanging up-----
If the track is not rolling--either the locking mechanism is defective ---or the track is hitting a screw head====
Old 01-17-2013, 07:11 AM   #10
Haverhill Trade 1965
The tracks must be secured to the door, can you remove the door so you can see how the track works without the weight of the door?
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
Newbie2013 (01-21-2013)
Old 01-18-2013, 07:59 AM   #11
I'll try as you suggested and re-tighten the screws...
Old 01-18-2013, 08:00 AM   #12
Not sure how or where to begin with dismantling the door/ trays as it is quite heavy! Any tips on how to start??
Old 01-19-2013, 03:47 PM   #13
DIY staff
You may need to enlist a helper----If you could get one that knows how to post pictures--that would be a help---many modern door hinges are quick release and just pop off after pressing a release button
Old 01-21-2013, 06:16 AM   #14
I couldnt find anything to tighten, nor could I find any obvious quick release buttons on the weekend... I'll try enlisting more help next weeekend although there is not much to photograph (the link to Nicolushka's post pretty much sums up my problem very nicely, pity he didnt post his answers!)
Thanks everyone for your time and suggestions!
Old 01-21-2013, 06:24 AM   #15
DIY staff
We need to know the exact brand and style of track---then we can pull up the instructiuns and tell you how to free it up--same with the hinges---
A lot of us here have built cabinets with hidden tracks---every brand has a little something different---so a picture will help
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
BigJim (01-21-2013), Taylor Rae (01-21-2013)
Tags
cabinet pulls , cabinetry , kitchen cabinets
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 25 01-26-2014 05:31 PM
Replacing window sill, but now it's stuck. rosemonster Carpentry 25 01-25-2011 04:31 AM
Kitchen remodel - pantry wall removal FLHC Remodeling 1 09-06-2010 11:32 AM
Pantry door problem. Mensch Carpentry 2 03-31-2010 10:28 PM
Request - Help needed for stuck Pantry Slide Nicolushka Carpentry 1 09-11-2009 12:59 AM
