-   -   Help with an old mortise handleset. (http://www.diychatroom.com/f14/help-old-mortise-handleset-153080/)
allisen 08-08-2012 04:17 PM
We have an old Mortise handleset on our front door. One with a handle and thumb-press on the outside and a door know on the inside. The problem is that the inside doorknob completely pulls out of the door if you pull on it. The knob itself pulls out as well as the stick part that goes into the door. The stick part consists of two long metal piece with knobs on the end. I think this is what is supposed to keep it in the mechanism but it doesn't anymore. Does anyone have any ideas of fixing or replacing just the knob portion?
BigJim 08-08-2012 06:39 PM
Check to see if there are marks on the shaft where a set screw was applied. If so then it should give you the location of where the set screw is and you can tighten it. If there are no signs of a set screw then ther may be a clip that has come off. If you could post some pictures it might help to see what you are working with.
joecaption 08-08-2012 07:21 PM
Loose, head stripped out, or stripped threads on the handles in the most common problums.
You going to need an allen wrench to fix it most times.
user1007 08-11-2012 06:04 AM
These folks are good with advice and often have parts for old door hardware. I have used them on many projects.
http://www.albarwilmette.com/hardwarerestoration/
Obviously you will want to provide pictures and as detailed a description as possible.
jschaben 08-11-2012 08:58 PM
If you don't need/want to keep the look, I have had good luck cleaning the old mortise up with a router and putting a solid wood plug in. Then redrill for a more modern lockset.:)
Maintenance 6 08-13-2012 03:58 PM
There should be a two piece spindle. One side has a bent over hook on the end. Held together there are threads on the outside to accept a knob. These parts are available. There is a square hub in the lockset that accepts this split spindle. If the hub has it's square center worn away, a replacement spindle may not stay in place. If you get new spindle and knob, slide the half of the spindle with a bent end in the hub first and hook it. Then slide the other half into the hub beside the first. Then thread the knob onto the spindle and until it rests in the escutcheon.
allisen 08-15-2012 10:16 AM
Sorry this took so long. Here are the pictures.
http://www.flickr.com/photos/8131179@N02/7788753186/
http://www.flickr.com/photos/8131179@N02/7788752358/
http://www.flickr.com/photos/8131179@N02/7788751376/
http://www.flickr.com/photos/8131179@N02/7788750128/
http://www.flickr.com/photos/8131179@N02/7788749062/
allisen 08-15-2012 10:18 AM
@Maintenance_6: It looks like that is exactly what I have going on based on the pictures I took. Do you know where I can get a replacement two piece spindle?
user1007 08-15-2012 12:20 PM
See my prior post. Wilmette will have it or can tell you where to get it.
Maintenance 6 08-17-2012 12:59 PM
You could try a local locksmith shop. Should be a stock item for an established shop.
Maintenance 6 08-17-2012 01:30 PM
Your picture shows a scissors type spindle, but a split spindle will work in the mortise set you have. In fact, it will work better in a worn hub than a scissors type.
