Help: No Place To Attach Top Plate - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-21-2009, 01:30 PM   #1
Help: No place to attach top plate
I am adding two walls (one 4ft and one 5.5 ft wall) to construct a small storeroom in a corner of a commercial building with a suspended ceiling. I will be attaching the 2 new walls perpendicullary to the 2 existing walls in the corner. Since the top plate will not be attached to anything (due to suspended ceiling), do you think the 2 small wall additions will be sturdy?
AlSmith is offline   Reply With Quote
Old 05-21-2009, 02:51 PM   #2
Old School
Willie T's Avatar
It's a pretty sturdy setup all on its own. But you would be surprised what just a couple of screws into the grid out near the corner will do. Admittedly, it may not be kosher, but my office had a few places done like that. Oops, did I just admit that?
Truly, though, the drywall will lock it in place well enough.
Willie T
Old 05-21-2009, 02:59 PM   #3
Thanks Willie T
Thanks Willie T!
Old 05-21-2009, 04:31 PM   #4
Rewards Points: 5,336
If you use a double top plate and overlap them, they won't go anywhere. You would also screw the corner stud together as an added connection. As Willie said, the drywall will add to the walls rigidity.
Ron
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
attach bottom plate to exizting slab Constant Improvement Building & Construction 1 02-04-2009 12:36 PM
doing up a basment littleparr Building & Construction 7 04-08-2008 08:28 PM
basement renovation yummy mummy Remodeling 156 05-08-2007 10:15 AM
Help! I need to know how to start finishing my basement. brightred Carpentry 47 01-18-2007 01:30 PM
